Forcing index.php rewrite for docker instance?
I’m currently running occ maintenance:update:htaccess to update the .htaccess file manually, but want to know if there is a more elegant way to do this? I want to remove the index.php from the path, but having to run this after I start the container is a bit of a pain. Thanks!
What image are you using?
Please post your Compose file and fill out the support template.
If you’re having to re-run this command after restarts, something is wrong with your environment or installation. That is not normal.
