Folders Missing in Web UI After occ files:scan – "Too many open files in system" Error
    • Mac Mini M4 Seqouia 15.5
    • nginx proxy manager (2.12.6)
    • yes
    • after manually adding files to the DATADIR and then running the scan
    • AIO on docker
    • no
Hi all,
I’m running Nextcloud on a Mac Mini using Docker Compose (specifically, the AIO setup). I’m trying to migrate a large number of folders (around 3,500 in total, roughly 12GB) directly into my Nextcloud DATA_DIR.
Here’s what I’m doing:
  1. I move the folders directly into my DATA_DIR - /System/Volumes/Data/mnt/truenas/nas/data/nextcloud/admin/files/Documents/.
  2. I then run the file scan command:
    docker exec -u www-data nextcloud-aio-nextcloud php occ files:scan --path="admin/files/Documents"
The scan completes without errors, but when I check the web interface, many of the folders appear empty or are completely missing.
To debug, I ran:
docker exec nextcloud-aio-nextcloud ls -la /mnt/ncdata/admin/files/Documents/Family
And I get this error for every subfolder inside Family:
ls: cannot access '/mnt/ncdata/admin/files/Documents/Family/Holidays': Too many open files in system
It seems like the system is hitting a file descriptor limit during the scan or access process?
My Questions:
  • Is this a known issue with files:scan handling large folder structures?
  • Do I need to increase the open file limit for the Nextcloud-AIO container during setup?
  • Would breaking the scan into smaller parts help (e.g., scanning per subdirectory)?
  • Any tips to handle large folder imports more reliably going forward?
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "nextcloud.homelab.local",
        "overwriteprotocol": "https",
            "localhost",
        "dbtype": "pgsql",
        "version": "31.0.6.2",
        "overwrite.cli.url": "https:\/\/nextcloud.homelab.local\/",
        "dbport": "",
        "updatechecker": false,
        "loglevel": 2,
        "log_type": "file",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "DOMAIN": "nextcloud.homelab.local"
  'one-click-instance' => true,
  'one-click-instance.user-limit' => 100,
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'check_data_directory_permissions' => false,
  'redis' =>
    'host' => 'nextcloud-aio-redis',
    'password' => 'fffffff',
    'port' => 6379,
  'overwritehost' => 'nextcloud.homelab.local',
  'passwordsalt' => 'ffffff',
  'secret' => 'fffff',
    0 => 'localhost',
    1 => 'nextcloud.homelab.local',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
  'version' => '31.0.6.2',
  'overwrite.cli.url' => 'https://nextcloud.homelab.local/',
  'dbname' => 'nextcloud_database',
  'dbhost' => 'nextcloud-aio-database:5432',
  'dbuser' => 'oc_nextcloud',
  'dbpassword' => 'fffffff',
  'instanceid' => 'ocdzqkdl3nt2',
  'updatechecker' => false,
  'loglevel' => 2,
  'log_type' => 'file',
  'logfile' => '/var/www/html/data/nextcloud.log',
  'log_rotate_size' => 10485760,
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'preview_max_x' => 2048,
  'preview_max_y' => 2048,
  'jpeg_quality' => 60,
  'enabledPreviewProviders' =>
    1 => 'OC\\Preview\\Image',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\MP3',
    4 => 'OC\\Preview\\TXT',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\Movie',
    7 => 'OC\\Preview\\Krita',
    0 => 'OC\\Preview\\Imaginary',
    23 => 'OC\\Preview\\ImaginaryPDF',
  'enable_previews' => true,
  'mail_smtpmode' => 'smtp',
  'versions_retention_obligation' => 'auto, 30',
  'activity_expire_days' => 30,
  'share_folder' => '/Shared',
  'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
  'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
  'updatedirectory' => '/nc-updater',
  'maintenance_window_start' => 100,
  'allow_local_remote_servers' => true,
  'davstorage.request_timeout' => 3600,
  'documentation_url.server_logs' => 'https://github.com/nextcloud/all-in-one/discussions/5425',
  'dbpersistent' => false,
  'auth.bruteforce.protection.enabled' => true,
  'ratelimit.protection.enabled' => true,
  'files_external_allow_create_new_local' => false,
  'trusted_proxies' =>
    0 => '127.0.0.1',
    1 => '::1',
    10 => '192.168.107.0/16',
  'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
  'preview_imaginary_key' => 'ffffffff',
    image: nextcloud/all-in-one:${NEXTCLOUD_AIO_VERSION}
    restart: unless-stopped
    volumes:
    ports:
      - 1010:8080
    environment:
      # Store Nextcloud data on NAS which is automounted
      - NEXTCLOUD_DATADIR=${DOCKER_MOUNT_STORAGE_DIR}/nextcloud
      - SKIP_DOMAIN_VALIDATION=true
      - APACHE_PORT=11000
      - APACHE_IP_BINDING=0.0.0.0
ulimit -n
if output is less than 3500 then increase it to bigger value
I am not much sure about manmini commands but try like below
sudo launchctl limit maxfiles 65536 65536
sudo nano /etc/sysctl.conf
kern.maxfiles=65536
kern.maxfilesperproc=65536
Save and exit. Reboot your Mac Mini to apply the changes.
After reboot check the values changed?
ulimit -n
Now try to if the values changed inside of container too?
docker exec -it nextcloud-aio-nextcloud bash
ulimit -n (It should return you same values as we set in your mac system)
exit
now again run scan
