Focus leaves comment field on autosave
    • Latest, but I've seen this with multiple versions
    • Pop!_OS 20.04
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
When I’m typing to-do’s (or any comments) in a Deck card, and the autosave triggers, my browser loses focus and I have to stop typing and move the mouse back over comments, click, and then continue. This will happen multiple times during my creation of a card.
  1. Create card
  2. Open card and start editing comments
  3. Pause briefly, long enough for autosave to execute.
Do others see this? Is there a solution? I’m using Brave for my browser.
I have the same problem and it’s really annoying. The behavior is the same in both Chrome and Edge.
As a regular deck user I cannot confirm.
My environment:
NC v30.0.5
Deck app v1.14.3
Browser Firefox v134.0.1
Interesting. I just tested in FireFox and still experience the issue.
What OS are you using?
@Jan-Philipp_Schmidtm, what OS are you using?
I am on macOS 15.2.
Just tested it on Win 11 on Arm as well using FF v133 and it works as well like exptected.
Any plugins / addons?
Win 10 and Win11 both have this issue for me. Sometimes it just works, sometimes it does not. Very frustrating.
Fair question. I have my password manager and React Dev tools. I opened both Brave and Firefox in private/incognito mode and they seemed to work (but, as @Jan-Philipp_Schmidtm indicated, this is not consistently an issue), so I’ll keep experimenting with that.
Early indications point towards the Bitwarden plugin being the cause.
But why?
However, I just turned the extension back on to test again while a dev console was open, and no issue with focus. Now I’m not as confident the culprit is the extension.
Does such extension has the functionality for field auto fill and auto type?
Not sure if this is related
There is an option to autofill fields, yes.
This morning, I was having focus issues in NextCloud and I disabled the Bitwarden extension. The problems went away.
I have not observed any problems with other websites/apps.
@Jan-Philipp_Schmidtm, disabling the autofill settings in the Bitwarden extension may solve the problem (I’ve opened a bug report with Bitwarden).
Have you tried changing extensions’ settings to see if the problem goes away for you?
I’m having the same issue; but with the 1Password extension.
I haven’t check if/how the extension can be inhibited for a specific website, and really hope it’s feasible as I don’t see myself going without my password manager active…
edit:
As of 1Password extension version 8.10.64.7, the following workarounds seem to work:
  1. For all websites
    In 1Password extension settings (not the specific item) in “Autofill & Save”, disable “Show autofill suggestions when a form field is in focus”
    All other options can be left active.
  2. For a specific page
    Right click on the page, and select “Hide on this page” from the 1Password context menu.
In Firefox (on MacOS), the ‘Adblock Plus’ plugin triggers the same behaviour. Disabling the plugin solved the issue for me. (In the Safari browser, without such a plugin, the problem never existed).
UPDATE: The problem returned so I tried enabling the ‘Adblock Plus’ plugin again. Problem was solved again!
This may have something to do with just updating the plugin registry - rather than the specific plugin involved.
