The first RC of Nextcloud 26 is now available on our download server!
If you notice anything out of order, please report back on the appropriate github repository!
Downloads
Changelog
- Adapt native tooltip for new structure of NcAvatar (server#36358)
- Chore(deps-dev): Bump symfony/event-dispatcher from 5.4.9 to 5.4.19 in /build/integration (server#36418)
- Feat(theming): Only convert a background image if it benefits from it (server#36471)
- Feat(translations): Add translation provider API (server#36584)
- Fix(caldav): Correctly handle calendar recreation for invitations when the current calendar is in the trashbin (server#36594)
- Fix(client-login-flow): Use correct response for missing state token (server#36634)
- Port admin delegation selects (server#36650)
- Add name for home breadcrumb in filepicker (server#36741)
- Fix broken search for tags in workflow checks (server#36754)
- Add back authentication checkbox for mailer settings (server#36785)
- [db]: Remove not supported column comments for SQLite (server#36803)
- Fix(SystemTagManager): Truncate overlong tag names (server#36837)
- Remove extraneous Node.js core module dependencies (server#36842)
- Port clear user status select (server#36843)
- Fix files breadcrumb spacing (server#36855)
- Fix typo that added a letter to migration template (server#36862)
- Convert tag id to number (closing #35645) (server#36866)
- Chore(deps-dev): Bump phpunit/phpunit from 9.5.28 to 9.6.4 in /build/integration (server#36878)
- Bump the hub number (server#36881)
- Fix(translation): Allow regular users to use translation api endpoints (server#36890)
- Fix(caldav): convert iMip recipient name to a string (server#36898)
- Chore(deps): Bump autosize from 5.0.1 to 6.0.1 (server#36902)
- Fix(theming): logo missing on login page (server#36930)
- Fix(theming): select “no-background” option and fix layout order (server#36931)
- Fix(caldav): harden null handling of iMip scheduling method (server#36935)
- Fix: treat text app session parameters as sensitive values (server#36936)
- Fix share select dropdown not opening when viewer is open (server#36998)
- Various unified search fixes (server#36999)
- Bump @nextcloud/vue from 7.7.0 to 7.8.0 (server#37005)
- Chore(deps-dev): Bump jest from 29.4.2 to 29.4.3 (activity#1091)
- Chore(deps-dev): Bump jest-environment-jsdom from 29.4.1 to 29.4.3 (activity#1093)
- Chore(deps-dev): Bump vimeo/psalm from 5.6.0 to 5.7.7 (activity#1094)
- Chore(deps-dev): Bump @nextcloud/eslint-config from 8.2.0 to 8.2.1 (activity#1095)
- [master] Update nextcloud/ocp dependency (activity#1099)
- Set imageResourcesPath to correct relative path (files_pdfviewer#689)
- Bump @nextcloud/logger from 2.4.0 to 2.5.0 (files_pdfviewer#698)
- Fix: hide back the unwanted buttons (files_pdfviewer#707)
- Bump cli-progress from 3.11.2 to 3.12.0 (files_pdfviewer#711)
- Add phpunit in composer (files_pdfviewer#712)
- Bump @nextcloud/vue from 7.5.0 to 7.7.1 (firstrunwizard#832)
- Chore(deps-dev): Bump vimeo/psalm from 5.6.0 to 5.7.7 (firstrunwizard#833)
- Copy log fixes (logreader#840)
- Bump vimeo/psalm from 5.6.0 to 5.7.7 (nextcloud_announcements#166)
- [master] Update nextcloud/ocp dependency (nextcloud_announcements#167)
- Chore(deps-dev): Bump vimeo/psalm from 5.6.0 to 5.7.7 (notifications#1463)
- Chore(deps): Bump @nextcloud/vue from 7.6.0 to 7.7.1 (notifications#1464)
- [master] Update nextcloud/ocp dependency (notifications#1465)
- Improve overall preview loading (photos#1647)
- Use full filenames in folder view (photos#1648)
- Perf(autoloader): Force own autoloader (photos#1651)
- Tidy up to broad rename from location to place (photos#1657)
- Take into account cropped layout setting (photos#1659)
- Chore(deps): Bump @nextcloud/vue from 7.4.0 to 7.6.0 (privacy#854)
- Remove unneeded attr
title
(privacy#859) - Fix internal links in direct-edit sessions (text#3442)
- Fix: solve publicly shared document with hide download issue (text#3765)
- Chore(deps): update dependency vite to ^4.1.4 (main) (text#3826)
- Fix(deps): update dependency lib0 to ^0.2.63 (main) (text#3827)
- Chore(deps-dev): Bump psalm/phar from 5.6.0 to 5.7.6 (text#3828)
- Fix(deps): update dependency yjs to ^13.5.47 (main) (text#3829)
- Chore(deps): update dependency cypress to ^12.7.0 (main) (text#3830)
- Fix(deps): update dependency @hocuspocus/provider to ^1.1.0 (main) (text#3831)
- Fix(deps): update dependency @nextcloud/l10n to ^2.1.0 (main) (text#3832)
- Fix(deps): update dependency @nextcloud/vue to ^7.7.1 (main) (text#3833)
- Fix: only one close request when closing viewer (text#3835)
- Fix: Bring back direct editing scrolling and fix scrollbar color (text#3839)
- Fix document state issues (text#3842)
- Add repair step to reset all sessions before Yjs migration (text#3843)
- Fix(deps): update tiptap to ^2.0.0-beta.219 (main) (text#3845)
- Fix: Provide file id for single file share links (text#3846)
- Shrink heading anchor links to
1em
, fixes links in headings (text#3847) - Fix(deps): update tiptap to ^2.0.0-beta.220 (main) (text#3854)
- Widget fixes (text#3856)
- Use NcRichText component from
@nextcloud/vue
(text#3859) - Fix: only load editor once even if connection is recovered (text#3868)
- Translate text (text#3869)
- Doc: how to open a shared file (viewer#1241)
- Handle 404 when opening files (viewer#1543)
- Chore(deps): Bump @nextcloud/dialogs from 3.2.0 to 4.0.1 (viewer#1551)
- Chore(deps): Bump @nextcloud/l10n from 2.0.0 to 2.1.0 (viewer#1557)
- Fix AxiosError when deleting photo in viewer (viewer#1560)
