from one moment to another I cant create a sharing link. please see the log.
can someone help me? Version 20.01
[PHP] Error: Error: Invalid argument supplied for foreach() at /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#158 at <>
- /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/serverinfo/lib/OperatingSystems/DefaultOs.php line 158
OC\Log\ErrorHandler::onError(2, “Invalid argument supplied for foreach()”, “/var/www/vhosts … p”, 158, {interfaces: false,result: []}) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/serverinfo/lib/Os.php line 132
OCA\ServerInfo\OperatingSystems\DefaultOs->getNetworkInterfaces() - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/serverinfo/lib/Settings/AdminSettings.php line 111
OCA\ServerInfo\Os->getNetworkInterfaces() - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/settings/lib/Controller/CommonSettingsTrait.php line 141
OCA\ServerInfo\Settings\AdminSettings->getForm() - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/settings/lib/Controller/AdminSettingsController.php line 83
OCA\Settings\Controller\AdminSettingsController->formatSettings([[OCA\ServerInfo … ]]) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/settings/lib/Controller/CommonSettingsTrait.php line 152
OCA\Settings\Controller\AdminSettingsController->getSettings(“serverinfo”) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/apps/settings/lib/Controller/AdminSettingsController.php line 68
OCA\Settings\Controller\AdminSettingsController->getIndexResponse(“admin”, “serverinfo”) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/lib/private/AppFramework/Http/Dispatcher.php line 169
OCA\Settings\Controller\AdminSettingsController->index(“serverinfo”) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/lib/private/AppFramework/Http/Dispatcher.php line 100
OC\AppFramework\Http\Dispatcher->executeController(OCA\Settings\Con … {}, “index”) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/lib/private/AppFramework/App.php line 152
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Settings\Con … {}, “index”) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/lib/private/Route/Router.php line 308
OC\AppFramework\App::main(“OCA\Settings\ … r”, “index”, OC\AppFramework\ … {}, {section: "serve … "}) - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/lib/base.php line 1009
OC\Route\Router->match("/settings/admin/serverinfo") - /var/www/vhosts/hosting147453.a2ea9.netcup.net/nextcloud.chipl.school/index.php line 37
OC::handleRequest()
GET /index.php/settings/admin/serverinfo from 77.11.169.60 by admin at 2020-10-28T06:59:06+00:00
example
longer
example
here
Nextcloud version (eg, 18.0.2):
Operating system and version (eg, Ubuntu 20.04):
PHP version (eg, 7.1):
PASTE HERE
PASTE HERE
PASTE HERE
