example
longer
example
here
Nextcloud version (eg, 12.0.2):
13.0.6
Operating system and version (eg, Ubuntu 17.04):
FreeBSD 11.2
nginx 1.14.0
PHP version (eg, 7.1):
7.2.9
When I try to upload a file (with the desktop client) whose filename contains an apostrophe '
the php-fpm processes start to hang at 100% CPU load until I manually restart the service.
- Try to upload this image as
- nothing revelant in the nextcloud logs
'instanceid' => 'something',
'passwordsalt' => 'somethingsomething',
'secret' => 'somethingsomethingsomething',
0 => 'something.example.com',
'datadirectory' => '/mnt/storagebox/nextclouddata',
'overwrite.cli.url' => 'https://something.example.com',
'dbtype' => 'pgsql',
'version' => '13.0.6.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => '',
'apps_paths' =>
0 =>
'path' => '/usr/local/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
'path' => '/usr/local/www/nextcloud/apps-pkg',
'url' => '/apps-pkg',
'writable' => false,
'mail_from_address' => 'something',
'mail_smtpmode' => 'php',
'mail_domain' => 'example.com',
'theme' => '',
'loglevel' => 2,
'integrity.check.disabled' => true,
- nothing useful in php-fpm.log or the nginx logs
I am using the nginx webroot settings from here: Nginx configuration — Nextcloud 13 Administration Manual 13 documentation
I am wondering if this is an issue with my nginx/php-fpm config and not a Nextcloud bug? Aside from the usual file size uploading hickups I had no big issues until I tried to upload some files with apostrophe in their names.
