example
longer
example
here
Nextcloud version (eg, 12.0.2): 14.3
Operating system and version (eg, Ubuntu 17.04): debian 9
Apache or nginx version (eg, Apache 2.4.25): 2.4.25
PHP version (eg, 7.1): 7.0
Files versions seems not work
- I have change files lot but it show No earlier versions available
- only one xlsx file in External storages seems work fine
'instanceid' => '',
'passwordsalt' => '//',
'secret' => '',
0 => '',
'datadirectory' => '/var/www/html/nextcloud/data',
'overwrite.cli.url' => 'https://',
'version' => '14.0.3.0',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'theme' => '',
'loglevel' => 2,
'updater.release.channel' => 'beta',
'mail_smtpmode' => 'smtp',
'mail_smtphost' => 'smtp.',
'mail_smtpport' => '',
'mail_smtpauth' => 1,
'mail_from_address' => '',
'mail_domain' => '',
'mail_smtpname' => '@',
'mail_smtppassword' => '',
'mail_smtpsecure' => '',
'updater.secret' => '$2y$10$',
