I have a problem with my nextcloud !
I have 5,4TB on my data folder on the system.
When I log me in the web interface, it shows 4,9TB.
So, I am afraid of missing files.
I tried to launch files:scan -all but not better.
I have Nextcloud version 17.0.2 on a CentOS 7 up to date.
mysql Ver 15.1 Distrib 10.4.11-MariaDB
Redis configured
Elasticsearch configured for fulltextsearch
Server version: Apache/2.4.6 (CentOS)
PHP 7.2.24
I have a specific mount point for /var/www/nextcloud/data
I determine the amount of my data with du -sh or df -h (same value)
I think it’s important for debug, I uploaded data through SSH
Thanks
I really do think, that you’ve got nothing to worry about. du or df will always report more allocated space as the WebUI will show, since du and df operate on the block levels of the underlying storage while the WebUi actually accounts for the “real” data used inside those blocks.
You would only came close to the same numbers, if you had only large files on that data folder. Also, I do think that the versioned files are nor accounted for, while du and df do count those as well.
