Hi nextcloudies,
on my config fulltextsearch works well with text, docs, pdf and so on but indexing of pics with tesseract seems to me is not fully implemented. On the command-line tesseract self works well.
If i try to index a jpg or png this error appears:
Error: 1/1
Index: files:1757
Exception: Class ‘OCP\FullTextSearch\Model\IndexDocument’ not found
Message: Error while getting file content
IMHO there is a problem with a Class Definition in
/var/www/html/custom_apps/files_fulltextsearch_tesseract/lib/Service/TesseractService.php
but me coding skills are really “down under” …
my config:
NC 16
fulltextsearch: 1.3.1
fulltextsearch_elasticsearch: 1.3.0
