Nextcloud version (eg, 12.0.2): 11.0.6
Operating system and version (eg, Ubuntu 17.04): Ubuntu 16.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.18
PHP version (eg, 7.1): Php 7.0.22
- Upgrade nextcloud from owncloud
- wait
|Warning|no app in context|Missing expected parameters in change user hook|2018-03-09T10:27:36+0100|
|Error|PHP|fclose() expects parameter 1 to be resource, boolean given at /var/www/nextcloud/lib/private/Files/Storage/Local.php#218|2018-03-09T10:27:36+0100|
|Error|PHP|fread() expects parameter 1 to be resource, boolean given at /var/www/nextcloud/lib/private/Files/Storage/Local.php#217|2018-03-09T10:27:36+0100|
|Error|PHP|fopen(/mnt/infocloud/appdata_oc3xzc0toftd/avatar/slevtchenko/avatar.jpg): failed to open stream: No such file or directory at /var/www/nextcloud/lib/private/Files/Storage/Local.php#216|2018-03-09T10:27:36+0100|
|Error|PHP|filesize(): stat failed for /mnt/infocloud/appdata_oc3xzc0toftd/avatar/slevtchenko/avatar.jpg at /var/www/nextcloud/lib/private/Files/Storage/Local.php#211|2018-03-09T10:27:36+0100|
|Warning|no app in context|Missing expected parameters in change user hook|2018-03-09T10:27:35+0100|
"updatechecker": false,
"instanceid": "oc3xzc0toftd",
"***server ip***",
"infocloud.domain.de"
"datadirectory": "\/mnt\/infocloud\/",
"overwrite.cli.url": "https:\/\/***server ip***\/",
"dbtype": "mysql",
"version": "11.0.6.1",
"logtimezone": "Europe\/Berlin",
"loglevel": 0,
"theme": "owncloud-theme-domain",
"mail_from_address": "infocloud",
"mail_smtpmode": "smtp",
"mail_domain": "domain.de",
"dbname": "infocloud_new",
"dbhost": "***database host ip***",
"ldapIgnoreNamingRules": false,
"singleuser": false,
"mail_smtphost": "***smtp host ip***",
"mail_smtpport": "25",
"ldapProviderFactory": "\\OCA\\User_LDAP\\LDAPProviderFactory",
"auth.bruteforce.protection.enabled": false
nothing interesting...
A user confronted me that he lost some files on his client. We confirmed they are also not present on disk layer on the server.
I see the files being create in table oc_activity but no deletion.
The sync logfiles on his client dont show any activity on these files so they could be removed long time ago.
How do I track down where the files are gone?
