example
longer
example
here
Nextcloud version (eg, 12.0.2): 15.02
Operating system and version (eg, Ubuntu 17.04): 16.04 xenial
Apache or nginx version (eg, Apache 2.4.25): 2.4
PHP version (eg, 7.1): 7.0
- logg into nextcloud server
- sudo -u www-data php /var/www/nextcloud/occ maintenance:mode --on
- sudo -u www-data php /var/www/nextcloud/occ db:convert-filecache-bigint
The only problem i have is that it is using way too much space and it cannot convert, i resized the nc database server by adding more space it has 25G free space atm, when the conversion occurs it fails due to insufficient space. Any idea how i can solve this ? Thanks.
