File Sync Problem on Surface Laptop 7 (ARM)
Good day to you all,
I’m observing a strange issue on my Surface Laptop 7 device. I have the Nextcloud AIO running on Docker, accessible via an Android phone and 2 other Windows 11 x64 laptops.
No problems.
On the Surface 7 Laptop it sometimes fails to sync files when I try to open them. Explorer will eventually give an error of:
"An unexpected error is keeping you from copying the file. If you continue to receive this error, you can use the error code to search for help with this problem.
Error 0x800701AA: The cloud operating was not completed before the time out period expired."
At this point the Nextcloud sync app gets stuck and just sits forever with “Checking folder changes” at the top.
Leaving the sync app for hours gives no difference. Restarting the computer resolves the problem. Sometimes I will open a JPG without issue, and another immediately after will crash the app.
Both the Nextcloud sync app and AIO are all on the latest versions.
I grabbed the client log file during one of these failures if this is useful, however I’d like to send it privately if requested.
Would appreciate if anyone has any input into how to resolve this.
