FIDO2 WebAuthn always asks for TOTP afterwards?
just to confirm if I understand this correctly: when I enable FIDO2/WebAuthn in Nextcloud AIO it works, but after using my YubiKey I still get prompted for TOTP.
So there is no way to configure it like other services (use either YubiKey/FIDO2 or TOTP), but instead Nextcloud always requires both if both are enabled?
Thanks!
Nextcloud Hub 10 (31.0.9)
I believe you can achieve that by using a twofactor exclusion group.
There is some activity related to integrating it in as toggle.
It may make sense as part of the integrated 2FA settings or the password_policy app.
Some thought needs to go into it because people want different things and there is also a twofactor_webauthn app for that matter…
I haven’t really kept up on the state at the moment so just going mostly from memory.
