Ich bekommen nach der Neuinstallation (Clickstart Anwendung bei Provider goneo) und Updates auf die Aktuellste Version: Nextcloud Hub 10 (31.0.6)
folgende Fehlermeldung:
Es gibt einige Fehler in Ihrer Systemkonfiguration.
An exception occured while running the setup check: InvalidArgumentException: URL is missing scheme or host in /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/public/SetupCheck/CheckServerResponseTrait.php:154 Stack trace: #0 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/public/SetupCheck/CheckServerResponseTrait.php(64): OCA\Settings\SetupChecks\WellKnownUrls->normalizeUrl() #1 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/public/SetupCheck/CheckServerResponseTrait.php(116): OCA\Settings\SetupChecks\WellKnownUrls->getTestUrls() #2 /data/web/1/000/034/590/110245/htdocs/Nextcloud/apps/settings/lib/SetupChecks/WellKnownUrls.php(57): OCA\Settings\SetupChecks\WellKnownUrls->runRequest() #3 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/private/SetupCheck/SetupCheckManager.php(34): OCA\Settings\SetupChecks\WellKnownUrls->run() #4 /data/web/1/000/034/590/110245/htdocs/Nextcloud/apps/settings/lib/Controller/CheckSetupController.php(134): OC\SetupCheck\SetupCheckManager->runAll() #5 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/private/AppFramework/Http/Dispatcher.php(200): OCA\Settings\Controller\CheckSetupController->check() #6 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/private/AppFramework/Http/Dispatcher.php(114): OC\AppFramework\Http\Dispatcher->executeController() #7 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/private/AppFramework/App.php(161): OC\AppFramework\Http\Dispatcher->dispatch() #8 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/private/Route/Router.php(307): OC\AppFramework\App::main() #9 /data/web/1/000/034/590/110245/htdocs/Nextcloud/lib/base.php(1040): OC\Route\Router->match() #10 /data/web/1/000/034/590/110245/htdocs/Nextcloud/index.php(24): OC::handleRequest() #11 {main}
30 Fehler in den Protokollen seit 13. Juni 2025, 11:30:47
In der config.php ist nur die Domain mit https:// hinterlegt! Keine IP Adresse (V4 / V6)
