Federation - Nextcloud AIO - Collabora - iframe
    • 32.0.6
    • Debian 13
    • Apache 2.4.66
    • Caddy 2.11.2
    • 8.3.30
    • yes
    • wanted to open a document oon a federated server
    • AIO
    • no
I want to open a document on a federated server and run into problems because of iframe embedding. Firefox says the host does not allow the frame to be displayed because I’m on the wrong host. I have added the respective server on both NC instances as trusted. (one is green, one is yellow).
I have applied this:
occ config:app:set richdocuments federation_use_trusted_domains --value="yes"
I have added the following Collabora variable in the AIO Mastercontainer under Collabora options
–o:net.content_security_policy= frame-ancestors *.thefederationserver.tld:*;
  1. Go to main nextcloud, to federated share
  2. Open Document
  3. get error
{"reqId":"LnlPG2UfeBTSFziXRwFt","level":3,"time":"2026-04-01T11:48:53+00:00","remoteAddr":"redacted","user":"--","app":"richdocuments","method":"POST","url":"/index.php/apps/richdocuments/remote?shareToken=ypJErszSGY1jmYp&remoteServer=https%3A%2F%2Fnextcloud.thefederationserver.tld%2F&remoteServerToken=MKMsBDJAG62Q5nnew40JpotC5GEYN5hJ","scriptName":"/index.php","message":"Invalid remote file details for MKMsBDJAG62Q5nnew40JpotC5GEYN5hJ","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:149.0) Gecko/20100101 Firefox/149.0","version":"32.0.6.1","exception":{"Exception":"Exception","Message":"Invalid remote file details for MKMsBDJAG62Q5nnew40JpotC5GEYN5hJ","Code":0,"Trace":[{"file":"/var/www/html/custom_apps/richdocuments/lib/Controller/DocumentController.php","line":306,"function":"remote","class":"OCA\\Richdocuments\\Controller\\DocumentController","type":"->","args":["ypJErszSGY1jmYp","https://nextcloud.thefederationserver.tld/","MKMsBDJAG62Q5nnew40JpotC5GEYN5hJ",null]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":204,"function":"remotePost","class":"OCA\\Richdocuments\\Controller\\DocumentController","type":"->","args":["ypJErszSGY1jmYp","https://nextcloud.thefederationserver.tld/","MKMsBDJAG62Q5nnew40JpotC5GEYN5hJ",null]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Richdocuments\\Controller\\DocumentController"},"remotePost"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Richdocuments\\Controller\\DocumentController"},"remotePost"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Richdocuments\\Controller\\DocumentController","remotePost",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"richdocuments.document.remotepost"}]},{"file":"/var/www/html/lib/base.php","line":1091,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/richdocuments/remote"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/custom_apps/richdocuments/lib/Controller/DocumentController.php","Line":267,"message":"Invalid remote file details for MKMsBDJAG62Q5nnew40JpotC5GEYN5hJ","exception":[],"CustomMessage":"Invalid remote file details for MKMsBDJAG62Q5nnew40JpotC5GEYN5hJ"},"id":"69cd0e2b57de4"}
cross origin request denied
no caddy logs
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "nextcloud.thefederationhost.tld",
        "overwriteprotocol": "https",
            "localhost",
            "192.168.2.3"
        "dbtype": "pgsql",
        "version": "32.0.6.1",
        "overwrite.cli.url": "https:\/\/nextcloud.thefederationhost.tld\/",
        "dbport": "",
        "loglevel": 2,
        "log_type": "file",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "skeletondirectory": "\/mnt\/ncdata\/skeleton",
        "mail_smtpsecure": "ssl",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpauth": 1,
        "default_phone_region": "CH",
        "defaultapp": "files",
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-musl",
        "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
        "updatechecker": false,
        "ncd_admin_settings": {
            "disallow_aria2_settings": "1"
        "app_install_overwrite": [
            "occweb"
        "forbidden_filename_basenames": [
            "con",
            "prn",
            "aux",
            "nul",
            "com0",
            "com1",
            "com2",
            "com3",
            "com4",
            "com5",
            "com6",
            "com7",
            "com8",
            "com9",
            "com\u00b9",
            "com\u00b2",
            "com\u00b3",
            "lpt0",
            "lpt1",
            "lpt2",
            "lpt3",
            "lpt4",
            "lpt5",
            "lpt6",
            "lpt7",
            "lpt8",
            "lpt9",
            "lpt\u00b9",
            "lpt\u00b2",
            "lpt\u00b3"
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
        "DOMAIN": "nextcloud.thefederationhost.tld",
        "AIO_VERSION": "v12.8.0"
occ $
  - activity: 5.0.0
  - admin_audit: 1.22.0
  - announcementcenter: 7.3.0
  - app_api: 32.0.0
  - bruteforcesettings: 5.0.0
  - calendar: 6.2.2
  - circles: 32.0.0
  - comments: 1.22.0
  - contacts: 8.3.7
  - contactsinteraction: 1.13.1
  - dav: 1.34.2
  - deck: 1.16.3
  - external: 7.0.0
  - federation: 1.22.0
  - files: 2.4.0
  - files_fulltextsearch: 32.0.2
  - files_lock: 32.0.2
  - files_pdfviewer: 5.0.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - forms: 5.2.5
  - fulltextsearch: 32.0.0
  - fulltextsearch_elasticsearch: 32.0.2
  - groupfolders: 20.1.12
  - impersonate: 3.0.1
  - keeweb: 0.6.22
  - logreader: 5.0.0
  - mail: 5.7.6
  - metadata: 0.23.0
  - nextcloud-aio: 0.8.0
  - nextcloud_announcements: 4.0.0
  - notes: 4.13.1
  - notifications: 5.0.0
  - notify_push: 1.3.1
  - oauth2: 1.20.0
  - occweb: 0.2.3
  - password_policy: 4.0.0
  - passwords: 2026.3.21
  - previewgenerator: 5.13.0
  - privacy: 4.0.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - recommendations: 5.0.0
  - related_resources: 3.0.0
  - richdocuments: 9.0.5
  - serverinfo: 4.0.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - spreed: 22.0.10
  - support: 4.0.0
  - survey_client: 4.0.0
  - systemtags: 1.22.0
  - tasks: 0.17.1
  - text: 6.0.1
  - theming: 2.7.0
  - twofactor_email: 2.8.5
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - whiteboard: 1.5.7
  - workflowengine: 2.14.0
  - assistant: 2.13.0 (installed 2.13.0)
  - collectives: 4.2.0 (installed 4.2.0)
  - context_chat: 5.3.1 (installed 5.3.1)
  - dashboard: 7.12.0 (installed 7.9.0)
  - encryption: 2.20.0
  - files_external: 1.24.1
  - firstrunwizard: 5.0.0 (installed 2.18.0)
  - integration_deepl: 2.1.0 (installed 2.1.0)
  - integration_google: 4.3.1 (installed 4.3.1)
  - integration_openai: 3.10.1 (installed 3.10.1)
  - memories: 7.8.2 (installed 7.8.2)
  - photos: 5.0.0 (installed 3.0.2)
  - suspicious_login: 10.0.0 (installed 8.0.0)
  - twofactor_nextcloud_notification: 6.0.0
  - user_ldap: 1.23.0
occ $
