Hi all, consider a server with multiple nextcloud instances, i.e.
- cloud-a.domain.com
cloud-b.domain.com
The server doesn’t own the public ip because it’s managed by the firewall (only port 80 and 443 are redirected).
The names cloud-a.domain.com and cloud-b.domain.com are resolved with the local ip, i.e. 192.168.10.2.
I create ssl certificates.
I will not be able to get federation work between these two instances right?
Am I forced to set natreflection on the firewall?
