Originally published at: February maintenance updates ahead of Nextcloud Hub 10 launch - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 8 or 9, we strongly recommend you to update to version 29.0.12 or 30.0.6 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
The updates include a number of important bug fixes and performance optimization, as well as other improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
- Nextcloud Hub 8 (version 29.0.12)
- Nextcloud Hub 9 (version 30.0.6)
Sign up for Nextcloud Hub 10 live premiere! 🚀
Nextcloud Hub 10 will be launched on February 25th at 2 PM (CET) in an online event. Register now to join the live presentation and be among the first to experience it!
- February 25, 2025 | 2 PM (CET) – 8 AM (ET)
Sign up for the global launch
Reserve your seat and be the first to discover all the updates in our next big release.
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
