Nextcloud version (eg, 18.0.2): 19
Operating system and version (eg, Ubuntu 20.04): Debian 10
Apache or nginx version (eg, Apache 2.4.25): Nexinx 1.14.2
PHP version (eg, 7.1): 7.4
Help!!
When trying to update from version 19 to 20, it gave me an error, I could not solve it so I thought about doing a new installation taking advantage of the database, but it gave me several errors, problems with encryption, etc.
Now I go back to the installation and it gives me the error indicated below. Already tired of not getting anything, the only thing that interests me is knowing how to do a new installation and migrate the current database to the new one.
2020/11/08 20:25:39 [error] 15168#15168: *57630 FastCGI sent in stderr: "PHP message: {"reqId":"nZCNxjpozZ6KvURVv9Th","level":3,"time":"2020-11-08T19:25:39+00:00","remoteAddr":"95.169.232.72","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/contacts/","message":{"Exception":"Error","Message":"Undefined index: name at /srv/www/nc/core/templates/update.admin.php#24","Code":0,"Trace":[{"file":"/srv/www/nc/core/templates/update.admin.php","line":24,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/srv/www/nc/lib/private/Template/Base.php","line":178,"args":["/srv/www/nc/core/templates/update.admin.php"],"function":"include"},{"file":"/srv/www/nc/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/www/nc/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/www/nc/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/srv/www/nc/lib/base.php","line...PHP message: {"reqId":"nZCNxjpozZ6KvURVv9Th","level":3,"time":"2020-11-08T19:25:39+00:00","remoteAddr":"95.169.232.72","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/contacts/","message":{"Exception":"Error","Message":"Undefined index: name at /srv/www/nc/core/templates/update.admin.php#24","Code":0,"Trace":[{"file":"/srv/www/nc/core/templates/update.admin.php","line":24,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/srv/www/nc/lib/private/Template/Base.php","line":178,"args":["/srv/www/nc/core/templates/update.admin.php"],"function":"include"},{"file":"/srv/www/nc/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/www/nc/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/srv/www/nc/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template",
2020/11/08 20:25:39 [error] 15168#15168: *57630 FastCGI sent in stderr: "jpozZ6KvURVv9Th","level":3,"time":"2020-11-08T19:25:39+00:00","remoteAddr":"95.169.232.72","user":"--","app":"no app in context","method":"GET","url":"/index.php/apps/contacts/","message":{"Exception":"OC\\Encryption\\Exceptions\\DecryptionFailedException","Message":"Encryption library: Decryption (symmetric) of content failed: error:0607A082:digital envelope routines:EVP_CIPHER_CTX_set_key_length:invalid key length","Code":0,"Trace":[{"file":"/srv/www/nc/apps/encryption/lib/Crypto/Crypt.php","line":482,"function":"decrypt","class":"OCA\\Encryption\\Crypto\\Crypt","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/nc/apps/encryption/lib/Crypto/Crypt.php","line":428,"function":"symmetricDecryptFileContent","class":"OCA\\Encryption\\Crypto\\Crypt","type":"->"},{"file":"/srv/www/nc/apps/encryption/lib/KeyManager.php","line":203,"function":"decryptPrivateKey","class":"OCA\\Encryption\\Crypto\\Crypt","type":"->","args":["*** sensitive parameters ...PHP message: {"reqId":"nZCNxjpozZ6KvURVv9Th","level":3,"time":"2020-11-08T19:25:39+00:00","remoteAddr":"95.169.232.72","user":"--","app":"jsresourceloader","method":"GET","url":"/index.php/apps/contacts/","message":"Could not find resource js/config.js to load","userAgent":"Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:82.0) Gecko/20100101 Firefox/82.0","version":"19.0.4.2"}PHP message: {"reqId":"nZCNxjpozZ6KvURVv9Th","level":3,"time":"2020-11-08T19:25:39+00:00","remoteAddr":"95.169.232.72","user":"--","app":"no app in context","method":"GET","url":"/index.php/apps/contacts/","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/srv/www/nc/lib/private/Route/Router.php","line":338,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/srv/www/nc/lib/priva
