Failing to transer Metadata between device and Application
example
longer
example
here
Nextcloud version (eg, 20.0.5): 27.1.9
Operating system and version: Arch Linux (Debian 12 running as an lxd container, where NextCloud is running)
Apache or nginx version: Caddy is my reverse proxy. Version 2.7.6
PHP version (eg, 7.4): 8.2.18
The issue you are facing: When uploading photos/vidoes off my phone onto NextCloud, the metadata is not preserved with it. Untested with files, but I would assume the same.
Is this the first time you’ve seen this error? (Y/N): Yes
  1. Open NextCloud (in my case on mobile)
  2. Upload photo/video, any amount (either manually or automatically)
There is no log for this.
  'apps_paths' =>
    0 =>
      'path' => '/snap/nextcloud/current/htdocs/apps',
      'url' => '/apps',
      'writable' => false,
    1 =>
      'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
      'url' => '/extra-apps',
      'writable' => true,
  'supportedDatabases' =>
    0 => 'mysql',
  'redis' =>
    'host' => '/tmp/sockets/redis.sock',
    'port' => 0,
  'log_type' => 'file',
  'logfile' => '/var/snap/nextcloud/current/logs/nextcloud.log',
  'logfilemode' => 416,
  'instanceid' => '[not showing]',
  'passwordsalt' => '[not showing',
  'secret' => '[not showing]',
    0 => '[Debian container IP]:[port]',
    1 => 'cloud.ionicpixels.com',
  'trusted_proxies' =>
    0 => '[Arch Host IP]',
  'forwarded_for_headers' =>
    0 => 'HTTP_X_FORWARDED_FOR',
    1 => 'HTTP_X_REAL_IP',
  'datadirectory' => '/var/snap/nextcloud/common/nextcloud/data',
  'version' => '27.1.9.1',
  'overwrite.cli.url' => 'http://[Debian container IP]:[port]',
  'overwritehost' => '[My domain]',
  'default_phone_region' => 'US',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
  'dbuser' => '[not showing',
  'dbpassword' => '[not showing]',
  'twofactor_enforced' => 'false',
  [E-Mail stuff]
doesn't show issue
PASTE HERE
Used to show the error in the admin user, no longer shows, issue not resolved.
