Hello, i setup collabora on my server and work fine, except because when i share a file and try to edit it i appear the next message
here are the docker logs:
wsd-00029-00331 2019-12-04 00:50:33.357841 [ docbroker_013 ] ERR Invalid or unknown session [16a] to remove.| wsd/DocumentBroker.cpp:1229 kit-00328-00031 2019-12-04 00:50:35.055436 [ kit_spare_013 ] WRN Setting TerminationFlag due to 'exit' command from parent.| kit/Kit.cpp:2076 wsd-00029-00030 2019-12-04 00:50:35.055619 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:1807 kit-00328-00031 2019-12-04 00:50:35.055785 [ kit_spare_013 ] WRN Kit connection lost without exit arriving from wsd. Setting TerminationFlag| kit/Kit.cpp:2112 wsd-00029-00335 2019-12-04 01:04:41.883349 [ docbroker_014 ] ERR WOPI::GetFile failed with 400 Bad Request| wsd/Storage.cpp:729 wsd-00029-00335 2019-12-04 01:04:41.883797 [ docbroker_014 ] ERR loading document exception: WOPI::GetFile failed| wsd/DocumentBroker.cpp:1193 wsd-00029-00335 2019-12-04 01:04:41.883846 [ docbroker_014 ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2] with URI [https://cloud.astian.org/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2?access_token=BWdERCOvHer0Z260pNqbrv9KuG2ZjIkG&access_token_ttl=0&reuse_cookies=nc_sameSiteCookielax%3Dtrue%3Anc_sameSiteCookiestrict%3Dtrue%3Aoces7qurc7l6%3Dqf7iao8976ohhmasmffh5sq8nj%3Aoc_sessionPassphrase%3DJxC4Kgif%2FU%2BhGdOHqTUM%2BvwqORbwOImsNgl%2FMmbhSntvUX3m0U2syJMQmm3ugPFsfjiAxp6S1VNFwh7sLQBFKTrqjh%2BDcl9hSn%2BVI6cD4PmqpxUd%2F3QdYg7GxSO1i4yG%3Aoc4ytnduldn2%3Djl0lqa8824dfusch6jte3q416t&permission=edit]: WOPI::GetFile failed| wsd/DocumentBroker.cpp:1155 wsd-00029-00335 2019-12-04 01:04:41.884236 [ docbroker_014 ] WRN Child session [16e] not found to forward message: load url=https://cloud.astian.org/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2?access_token=BWdERCOvHer0Z260pNqbrv9KuG2ZjIkG&access_token_ttl=0&reuse_cookies=nc_sameSiteCookielax%3Dtrue%3Anc_sameSiteCookiestrict%3Dtrue%3Aoces7qurc7l6%3Dqf7iao8976ohhmasmffh5sq8nj%3Aoc_sessionPassphrase%3DJxC4Kgif%2FU%2BhGdOHqTUM%2BvwqORbwOImsNgl%2FMmbhSntvUX3m0U2syJMQmm3ugPFsfjiAxp6S1VNFwh7sLQBFKTrqjh%2BDcl9hSn%2BVI6cD4PmqpxUd%2F3QdYg7GxSO1i4yG%3Aoc4ytnduldn2%3Djl0lqa8824dfusch6jte3q416t&permission=ed...| wsd/DocumentBroker.cpp:1808 wsd-00029-00335 2019-12-04 01:04:42.093761 [ docbroker_014 ] ERR Invalid or unknown session [16e] to remove.| wsd/DocumentBroker.cpp:1229 kit-00332-00031 2019-12-04 01:04:43.885274 [ kit_spare_014 ] WRN Setting TerminationFlag due to 'exit' command from parent.| kit/Kit.cpp:2076 kit-00332-00031 2019-12-04 01:04:43.885481 [ kit_spare_014 ] WRN Kit connection lost without exit arriving from wsd. Setting TerminationFlag| kit/Kit.cpp:2112 wsd-00029-00030 2019-12-04 01:04:57.802882 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:1807 wsd-00029-00339 2019-12-04 02:48:21.123478 [ docbroker_015 ] ERR WOPI::GetFile failed with 400 Bad Request| wsd/Storage.cpp:729 wsd-00029-00339 2019-12-04 02:48:21.124165 [ docbroker_015 ] ERR loading document exception: WOPI::GetFile failed| wsd/DocumentBroker.cpp:1193 wsd-00029-00339 2019-12-04 02:48:21.124263 [ docbroker_015 ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2] with URI [https://cloud.astian.org/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2?access_token=hVcpQvmzQ6QgfvOTlksGoWeyLIbffzH7&access_token_ttl=0&permission=edit]: WOPI::GetFile failed| wsd/DocumentBroker.cpp:1155 wsd-00029-00339 2019-12-04 02:48:21.124958 [ docbroker_015 ] WRN Child session [17f] not found to forward message: load url=https://cloud.astian.org/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2?access_token=hVcpQvmzQ6QgfvOTlksGoWeyLIbffzH7&access_token_ttl=0&permission=edit authorid=DevDorrejo xauthorid=DevDorrejoDevDorrejo author=Walddys%20Emmanuel%20Dorrejo%20C%C3%A9spedes xauthor=Walddys%20Emmanuel%20Dorrejo%20C%C3%A9spedesWalddys%20Emmanuel%20Dorrejo%20C%C3%A9spedes authorextrainfo=%7B%0A%20%20%22avatar%22%20:%20%22https:%5C/%5C/cloud.astian.org%5C/index.php%5C/avatar%5C/DevDorrejo%5C/32%22%0...| wsd/DocumentBroker.cpp:1808 wsd-00029-00339 2019-12-04 02:48:21.610170 [ docbroker_015 ] ERR Invalid or unknown session [17f] to remove.| wsd/DocumentBroker.cpp:1229 wsd-00029-00030 2019-12-04 02:48:23.125965 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:1807 kit-00336-00031 2019-12-04 02:48:23.126046 [ kit_spare_015 ] WRN Setting TerminationFlag due to 'exit' command from parent.| kit/Kit.cpp:2076 kit-00336-00031 2019-12-04 02:48:23.126301 [ kit_spare_015 ] WRN Kit connection lost without exit arriving from wsd. Setting TerminationFlag| kit/Kit.cpp:2112 wsd-00029-00369 2019-12-04 15:21:41.717161 [ docbroker_017 ] WRN Tracker tileID 0:0:7680:3840:3840:0 was dropped because of time out (5012 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00369 2019-12-04 15:21:41.717293 [ docbroker_017 ] WRN Tracker tileID 0:3840:7680:3840:3840:0 was dropped because of time out (5011 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00369 2019-12-04 15:21:41.793949 [ docbroker_017 ] WRN Tracker tileID 1:0:0:7080:12180:0 was dropped because of time out (5045 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00369 2019-12-04 15:21:42.275800 [ docbroker_017 ] WRN Tracker tileID 2:0:0:7080:12180:0 was dropped because of time out (5477 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:52:25.714611 [ docbroker_019 ] WRN Client session [1b9] not found to forward message: o7462 commandvalues: {...| wsd/DocumentBroker.cpp:1850 wsd-00029-00398 2019-12-04 15:52:25.714721 [ docbroker_019 ] WRN Client session [1b9] not found to forward message: o7463 commandvalues: | wsd/DocumentBroker.cpp:1850 kit-00377-00402 2019-12-04 15:52:26.455378 [ kitbroker_019 ] ERR No socket associated with WebSocketHandler 0x10920c80| ./net/WebSocketHandler.hpp:125 kit-00377-00402 2019-12-04 15:52:26.458759 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [GRAPHIC_VIEW_SELECTION] [{ "viewId": "1", "part": "0", "selection": "EMPTY" }] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.458802 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [CONTEXT_CHANGED] [com.sun.star.drawing.DrawingDocument DrawPage] message to MasterSession.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.459667 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [CONTEXT_CHANGED] [com.sun.star.drawing.DrawingDocument DrawPage] message to MasterSession.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.459708 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [CONTEXT_CHANGED] [com.sun.star.drawing.DrawingDocument DrawPage] message to MasterSession.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463293 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Context=] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463348 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Redo=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463371 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Undo=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463391 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Cut=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463421 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Copy=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463452 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Paste=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463471 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:SelectAll=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463493 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:TransformDialog=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463514 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:OutlineBullet=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463537 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:ThesaurusDialog=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463558 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:FontDialog=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463575 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:ParagraphDialog=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463593 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:InsertSymbol=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463609 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:SpellOnline=true] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463627 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:InsertPage=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463669 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DeletePage=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463699 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DuplicatePage=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463720 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DocumentRepair=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463738 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:ModifiedStatus=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463757 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:StyleApply=] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463777 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:CharFontName=Liberation Sans] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463796 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Italic=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463815 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Bold=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463834 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Shadowed=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463856 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Strikeout=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463876 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Underline=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463894 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:FontHeight=18] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463914 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:Color=-1] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463933 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:LeftPara=true] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463951 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:RightPara=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463969 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:CenterPara=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.463988 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:JustifyPara=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464006 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:SuperScript=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464025 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:SubScript=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464044 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:CharBackColor=-1] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464063 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DefaultBullet=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464082 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DefaultNumbering=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464101 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:OutlineFont=false] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464121 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:InsertColumnsBefore=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464142 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:InsertColumnsAfter=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464161 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:InsertRowsBefore=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.464181 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:InsertRowsAfter=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465148 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:LanguageStatus=Spanish (Colombia)] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465194 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DeleteRows=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465214 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DeleteColumns=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465234 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:SelectTable=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465253 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:EntireColumn=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465274 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:EntireRow=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465293 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:TableDialog=disabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465313 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:DeleteAnnotation=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465332 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:InsertAnnotation=enabled] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465367 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:PageStatus=Diapositiva 1 de 214] message to Master Session.| kit/Kit.cpp:1893 kit-00377-00402 2019-12-04 15:52:26.465401 [ kitbroker_019 ] WRN Document::ViewCallback. Session [0] is no longer active to process [STATE_CHANGED] [.uno:LayoutStatus=Predeterminado] message to Master Session.| kit/Kit.cpp:1893 kit-00370-00380 2019-12-04 15:53:35.660631 [ kitbroker_018 ] ERR No socket associated with WebSocketHandler 0x10945320| ./net/WebSocketHandler.hpp:125 kit-00370-00380 2019-12-04 15:56:35.493238 [ kitbroker_018 ] ERR No socket associated with WebSocketHandler 0x10945980| ./net/WebSocketHandler.hpp:125 kit-00377-00402 2019-12-04 15:59:20.379235 [ kitbroker_019 ] ERR No socket associated with WebSocketHandler 0x10920c80| ./net/WebSocketHandler.hpp:125 wsd-00029-00398 2019-12-04 15:59:44.618921 [ docbroker_019 ] WRN Tracker tileID 0:3840:0:3840:3840:0 was dropped because of time out (5495 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619056 [ docbroker_019 ] WRN Tracker tileID 0:7680:0:3840:3840:0 was dropped because of time out (5495 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619079 [ docbroker_019 ] WRN Tracker tileID 0:0:3840:3840:3840:0 was dropped because of time out (5495 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619178 [ docbroker_019 ] WRN Tracker tileID 0:3840:3840:3840:3840:0 was dropped because of time out (5495 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619200 [ docbroker_019 ] WRN Tracker tileID 0:7680:3840:3840:3840:0 was dropped because of time out (5495 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619221 [ docbroker_019 ] WRN Tracker tileID 0:0:7680:3840:3840:0 was dropped because of time out (5494 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619251 [ docbroker_019 ] WRN Tracker tileID 0:3840:7680:3840:3840:0 was dropped because of time out (5494 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619268 [ docbroker_019 ] WRN Tracker tileID 0:7680:7680:3840:3840:0 was dropped because of time out (5494 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 wsd-00029-00398 2019-12-04 15:59:44.619285 [ docbroker_019 ] WRN Tracker tileID 0:0:11520:3840:3840:0 was dropped because of time out (5494 ms). Tileprocessed message did not arrive in time.| wsd/ClientSession.cpp:1223 kit-00377-00402 2019-12-04 16:12:46.090993 [ kitbroker_019 ] ERR No socket associated with WebSocketHandler 0x10920c80| ./net/WebSocketHandler.hpp:125 kit-00377-00402 2019-12-04 16:15:35.392365 [ kitbroker_019 ] ERR No socket associated with WebSocketHandler 0x10920c80| ./net/WebSocketHandler.hpp:125 kit-00377-00402 2019-12-04 16:16:31.605599 [ kitbroker_019 ] ERR No socket associated with WebSocketHandler 0x10920c80| ./net/WebSocketHandler.hpp:125 wsd-00029-00398 2019-12-04 16:16:44.754458 [ docbroker_019 ] WRN Client session [1fb] not found to forward message: o9244 status: type=drawing parts=214 current=0 width=9600 height=13620 viewid=6| wsd/DocumentBroker.cpp:1850 wsd-00029-00398 2019-12-04 16:16:44.754573 [ docbroker_019 ] WRN Client session [1fb] not found to forward message: o9247 editor: -1| wsd/DocumentBroker.cpp:1850 kit-00377-00402 2019-12-04 16:16:44.770598 [ kitbroker_019 ] ERR No socket associated with WebSocketHandler 0x10920c80| ./net/WebSocketHandler.hpp:125 kit-00377-00402 2019-12-04 16:16:44.770812 [ kitbroker_019 ] WRN Document::ViewCallback. Session [6] is no longer active to process [GRAPHIC_VIEW_SELECTION] [{ "viewId": "1", "part": "0", "selection": "EMPTY" }] message to Master Session.| kit/Kit.cpp:1893 kit-00399-00439 2019-12-04 17:06:45.276775 [ kitbroker_01a ] ERR No socket associated with WebSocketHandler 0x4a67300| ./net/WebSocketHandler.hpp:125 kit-00399-00439 2019-12-04 17:06:45.276960 [ kitbroker_01a ] WRN Document::ViewCallback. Session [1] is no longer active to process [CONTEXT_CHANGED] [com.sun.star.drawing.DrawingDocument DrawPage] message to MasterSession.| kit/Kit.cpp:1893 kit-00399-00439 2019-12-04 17:06:45.276993 [ kitbroker_01a ] WRN Document::ViewCallback. Session [1] is no longer active to process [CONTEXT_CHANGED] [com.sun.star.drawing.DrawingDocument DrawPage] message to MasterSession.| kit/Kit.cpp:1893 wsd-00029-00469 2019-12-04 20:20:40.012522 [ docbroker_01b ] ERR WOPI::GetFile failed with 400 Bad Request| wsd/Storage.cpp:729 wsd-00029-00469 2019-12-04 20:20:40.013372 [ docbroker_01b ] ERR loading document exception: WOPI::GetFile failed| wsd/DocumentBroker.cpp:1193 wsd-00029-00469 2019-12-04 20:20:40.013766 [ docbroker_01b ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2] with URI [https://cloud.astian.org/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2?access_token=wVTU2WcVwc5nfOAVrOwTKR64fW4qrPOd&access_token_ttl=0&reuse_cookies=nc_sameSiteCookielax%3Dtrue%3Anc_sameSiteCookiestrict%3Dtrue%3Aoces7qurc7l6%3Dqf7iao8976ohhmasmffh5sq8nj%3Aoc_sessionPassphrase%3DJxC4Kgif%2FU%2BhGdOHqTUM%2BvwqORbwOImsNgl%2FMmbhSntvUX3m0U2syJMQmm3ugPFsfjiAxp6S1VNFwh7sLQBFKTrqjh%2BDcl9hSn%2BVI6cD4PmqpxUd%2F3QdYg7GxSO1i4yG%3Aoc4ytnduldn2%3Djl0lqa8824dfusch6jte3q416t&permission=edit]: WOPI::GetFile failed| wsd/DocumentBroker.cpp:1155 wsd-00029-00469 2019-12-04 20:20:40.014931 [ docbroker_01b ] WRN Child session [208] not found to forward message: load url=https://cloud.astian.org/index.php/apps/richdocuments/wopi/files/1032_oc4ytnduldn2?access_token=wVTU2WcVwc5nfOAVrOwTKR64fW4qrPOd&access_token_ttl=0&reuse_cookies=nc_sameSiteCookielax%3Dtrue%3Anc_sameSiteCookiestrict%3Dtrue%3Aoces7qurc7l6%3Dqf7iao8976ohhmasmffh5sq8nj%3Aoc_sessionPassphrase%3DJxC4Kgif%2FU%2BhGdOHqTUM%2BvwqORbwOImsNgl%2FMmbhSntvUX3m0U2syJMQmm3ugPFsfjiAxp6S1VNFwh7sLQBFKTrqjh%2BDcl9hSn%2BVI6cD4PmqpxUd%2F3QdYg7GxSO1i4yG%3Aoc4ytnduldn2%3Djl0lqa8824dfusch6jte3q416t&permission=ed...| wsd/DocumentBroker.cpp:1808 wsd-00029-00469 2019-12-04 20:20:40.204276 [ docbroker_01b ] ERR Invalid or unknown session [208] to remove.| wsd/DocumentBroker.cpp:1229 kit-00436-00031 2019-12-04 20:20:42.015398 [ kit_spare_01b ] WRN Setting TerminationFlag due to 'exit' command from parent.| kit/Kit.cpp:2076 wsd-00029-00030 2019-12-04 20:20:42.015493 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:1807 kit-00436-00031 2019-12-04 20:20:42.015651 [ kit_spare_01b ] WRN Kit connection lost without exit arriving from wsd. Setting TerminationFlag| kit/Kit.cpp:2112 wsd-00029-00038 2019-12-04 20:53:56.796498 [ websrv_poll ] ERR Socket #15 SSL BIO error: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca (0: Success)| ./net/SslSocket.hpp:281 wsd-00029-00038 2019-12-04 20:53:56.797418 [ websrv_poll ] ERR Error while handling poll for socket #15 in websrv_poll: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca| ./net/Socket.hpp:570 wsd-00029-00038 2019-12-04 20:54:11.442959 [ websrv_poll ] ERR Socket #15 SSL BIO error: error:1407609C:SSL routines:SSL23_GET_CLIENT_HELLO:http request (0: Success)| ./net/SslSocket.hpp:281 wsd-00029-00038 2019-12-04 20:54:11.443074 [ websrv_poll ] ERR Error while handling poll for socket #15 in websrv_poll: error:1407609C:SSL routines:SSL23_GET_CLIENT_HELLO:http request| ./net/Socket.hpp:570 wsd-00029-00038 2019-12-04 20:54:32.391016 [ websrv_poll ] ERR Socket #15 SSL BIO error: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca (0: Success)| ./net/SslSocket.hpp:281 wsd-00029-00038 2019-12-04 20:54:32.391155 [ websrv_poll ] ERR Error while handling poll for socket #15 in websrv_poll: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca| ./net/Socket.hpp:570 wsd-00029-00038 2019-12-04 20:55:59.212113 [ websrv_poll ] ERR Socket #15 SSL BIO error: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca (0: Success)| ./net/SslSocket.hpp:281 wsd-00029-00038 2019-12-04 20:55:59.212326 [ websrv_poll ] ERR Error while handling poll for socket #15 in websrv_poll: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca| ./net/Socket.hpp:570
curl -v --tlsv1.2 https://127.0.0.1:9980/hosting/discovery
- Trying 127.0.0.1…
- TCP_NODELAY set
- Connected to 127.0.0.1 (127.0.0.1) port 9980 (#0)
- ALPN, offering h2
- ALPN, offering http/1.1
- TLSv1.2 (OUT), TLS handshake, Client hello (1):
- TLSv1.2 (IN), TLS handshake, Server hello (2):
- TLSv1.2 (IN), TLS handshake, Certificate (11):
- TLSv1.2 (OUT), TLS alert, Server hello (2):
- SSL certificate problem: self signed certificate in certificate chain
- stopped the pause stream!
- Closing connection 0
curl: (60) SSL certificate problem: self signed certificate in certificate chain
More details here: https://curl.haxx.se/docs/sslcerts.htmlcurl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
