example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.3 (or 23.0.4)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): latest
PHP version (eg, 7.4): 7.4
Failed doing a backup with the backup plugin. Then wrote a script to backup files and DB. Then bash script failed partially because of permission issues. Then moved to backup folder and inadvertently executed an occ command within the folder.
Now the main Nextcloud instance is showing me “Looks like you’re trying to install NextCloud again”. I can’t connect to DB anymore.
I think I was able to backup all “drive” files, but I’m worried I will miss critical data from the database.
How can I reverse the process.
- Try to copy/paste nextcloud folder into a backup location + dump database
- execute occ command from the backup location
- Try starting the main nextcloud instance again.
Here is a screenshot of the current message:
I don’t want to reinstall. I would like to restore to previous state, if possible.
For what it’s worth, here is the script I had written to generate the backup, which failed:
#!/bin/sh
echo "Reminder: This needs to be run from the nextcloud folder!!"
export WDIR=`date +"%Y%m%d"`
sudo -u www-data php occ maintenance:mode --on
sudo mkdir ~/backups
sudo mkdir ~/backups/nextcloud
cd ~/backups/nextcloud
sudo mkdir $WDIR
sudo cp /var/www/nextcloud $WDIR -R
sudo chown $1 $WDIR -R
#sudo mysqldump --single-transaction --default-character-set=utf8mb4 -h localhost -u $2 -p$3 $4 | gzip > $WDIR/nextcloud-$WDIR.sql.gz
sudo zip -r ../nextcloud-$WDIR.zip ./$WDIR/
sudo chown $1 ../nextcloud-$WDIR.zip
#sudo rm -rf $WDIR
sudo -u www-data php occ maintenance:mode --off
Thanks for your help.
At this stage, I don’t think any other log is going help finding a solution. Correct me if I am wrong. Thanks for your understanding.
Best,
