amam
#1
Can’t load Collabora Online - try later
After upgrade Nextcloud to 18 version Collabora doesn’t work
I can get access to
https://blahblahblah/loleaflet/dist/admin/adminSettings.html
both can get
https://blahblahblah/hosting/discovery
but when I try to open some document I have notice in Nextcloud window
" Failed to load Collabora Online - please try again later"
when I try to open some doctype
example https://blhblah/loleaflet/be45e63/loleaflet.html
“Wrong or missing WOPISrc parameter, please contact support.”
Try this app instead Collabora Online https://apps.nextcloud.com/apps/wopi
And systemctl restart docker
amam
#3
it was installation without docker
I tryed this app and have same problem. at the beginning open a blank window and some later notification “failed to load Collabora…”
Жаль. У меня была та же проблема помогло перезапустить докер и установка WOPI. Попробуй перезапустить сам сервис Collabora
amam
#5
resolved
I’m add new name server to /etc/resolve.conf
example:
nameserver 8.8.8.8
