Face recognition, how to Maximum memory assigned for image processing?
    • 31.0.9
    • TrueNas 25.04.2.1
    • nginx 2.0.33
    • nginx 2.0.33
    • 8.3.25
    • yes
    • first installation
    • docker
    • no
New installation of Nextcloud, with Photo and face recognition
the recognition complain about this
Configuration information
Current model: Not installed
Maximum memory assigned for image processing: Not configured.
Seems that you still have to configure the assigned memory for image processing.
I’ve configured the Max memory for the app but I can’t find how to set the max memory for the face recognition
php occ face:setup
Current setup:
Minimum value to assign to image processing.: 682.7 MB (715827882B)Maximum value to assign to image processing.: 4 GB (4294967296B)Maximum memory assigned for image processing: Pending configuration
Available models:
| Id | Enabled | Name           | Description        |
| 1  |         | Default        | Main model, using dlib defaults.                                                |
| 2  |         | DlibCnn68      | DEPRECATED: Alternative default model, using dlib with 68 point landmarks model |
| 3  |         | DlibHog        | Dlib HOG Model which needs lower requirements                                   |
| 4  |         | DlibCnnHog5    | Extends the main model, doing a face validation with the Hog detector           |
| 5  |         | ExternalModel  | External model to separate image processing from the web server                 |
| 6  |         | DlibTaguchiHog | Extends the Taguchi model, doing a face validation with the Hog detector        |
# php occ config:list
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwriteprotocol": "https",
        "upgrade.disable-web": true,
        "dbtype": "pgsql",
        "version": "31.0.9.1",
        "overwrite.cli.url": "https:\/\/localhost",
        "dbport": "",
            "127.0.0.1",
            "192.168.*.*",
            "localhost",
            "nextcloud",
            "nginx"
    "apps": {
        "activity": {
            "installed_version": "4.0.0",
            "types": "filesystem",
            "enabled": "yes"
        "app_api": {
            "installed_version": "5.0.2",
            "types": "",
            "enabled": "yes"
        "backgroundjob": {
            "lastjob": "87"
        "bookmarks": {
            "enabled": "yes",
            "installed_version": "15.2.0",
            "types": ""
        "bruteforcesettings": {
            "types": "",
            "enabled": "yes"
        "calendar": {
            "installed_version": "5.5.7",
            "types": "",
            "enabled": "yes"
        "certificate24": {
            "installed_version": "0.3.7",
            "types": "dav",
            "enabled": "yes"
        "circles": {
            "installed_version": "31.0.0",
            "types": "filesystem,dav",
            "enabled": "yes",
            "loopback_tmp_scheme": "https",
            "maintenance_run": "0",
            "maintenance_update": "{\"3\":1758716219,\"2\":1758716219,\"1\":1758716219}"
        "cloud_federation_api": {
            "installed_version": "1.14.0",
            "enabled": "yes"
        "comments": {
            "installed_version": "1.21.0",
            "types": "logging",
            "enabled": "yes"
        "contactsinteraction": {
            "installed_version": "1.12.0",
            "types": "dav",
            "enabled": "yes"
        "context_chat": {
            "installed_time": 1760532324,
            "installed_version": "4.5.0",
            "types": "",
            "enabled": "yes",
            "providers": "{\"files__default\":{\"isInitiated\":true,\"classString\":\"\"},\"bookmarks__bookmarks\":{\"isInitiated\":false,\"classString\":\"OCA\\\\Bookmarks\\\\ContextChat\\\\ContextChatProvider\"}}"
        "cookbook": {
            "types": "",
            "enabled": "yes",
            "installed_version": "0.11.4"
        "core": {
            "installedat": "1758715319.114",
            "vendor": "nextcloud",
            "public_files": "files_sharing\/public.php",
            "lastupdatedat": 1760535321,
            "lastupdateResult": "{\"version\":\"32.0.0.13\",\"versionstring\":\"Nextcloud 32.0.0\",\"url\":\"https:\\\/\\\/download.nextcloud.com\\\/server\\\/releases\\\/nextcloud-32.0.0.zip\",\"web\":\"https:\\\/\\\/docs.nextcloud.com\\\/server\\\/32\\\/admin_manual\\\/maintenance\\\/upgrade.html\",\"changes\":\"https:\\\/\\\/updates.nextcloud.com\\\/changelog_server\\\/?version=32.0.0\",\"autoupdater\":\"1\",\"eol\":\"0\"}",
            "metadataGenerationLastHandledUser": "cris",
            "lastcron": 1760532983,
            "backgroundjobs_mode": "cron",
            "files_metadata": {
                "photos-original_date_time": {
                    "value": null,
                    "type": "int",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "photos-size": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-exif": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-ifd0": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-gps": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "blurhash": {
                    "value": null,
                    "type": "string",
                    "etag": "35645c9999380f5d77791a4d010f2f6f",
                    "indexed": false,
                    "editPermission": 0
                "photos-place": {
                    "value": null,
                    "type": "string",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
            "oc.integritycheck.checker": []
        "dashboard": {
            "installed_version": "7.11.0",
            "types": "",
            "enabled": "yes"
        "dav": {
            "installed_version": "1.33.0",
            "enabled": "yes"
        "facerecognition": {
            "installed_version": "0.9.70",
            "enabled": "yes",
            "handle_shared_files": "true"
        "federatedfilesharing": {
            "types": "",
            "enabled": "yes"
        "federation": {
            "types": "authentication",
            "enabled": "yes"
        "files": {
            "installed_version": "2.3.1",
            "enabled": "yes"
        "files_downloadlimit": {
            "types": "",
            "enabled": "yes"
        "files_pdfviewer": {
            "types": "",
            "enabled": "yes"
        "files_reminders": {
            "installed_version": "1.4.0",
            "types": "",
            "enabled": "yes"
        "files_sharing": {
            "installed_version": "1.23.1",
            "enabled": "yes"
        "files_trashbin": {
            "enabled": "yes"
        "files_versions": {
            "installed_version": "1.24.0",
            "enabled": "yes"
        "fileslibreofficeedit": {
            "installed_version": "2.0.1",
            "types": "",
            "enabled": "yes"
        "firstrunwizard": {
            "types": "",
            "enabled": "yes"
        "impersonate": {
            "installed_version": "2.0.0",
            "types": "prevent_group_restriction",
            "enabled": "yes"
        "integration_deepl": {
            "types": "",
            "enabled": "yes"
        "logreader": {
            "types": "logging",
            "enabled": "yes"
        "lookup_server_connector": {
            "installed_version": "1.19.0",
            "enabled": "yes"
        "maps": {
            "installed_version": "1.6.0",
            "enabled": "yes"
        "mediadc": {
            "installed_version": "0.4.0",
            "types": "",
            "enabled": "yes"
        "money": {
            "installed_version": "0.30.0",
            "types": "",
            "enabled": "yes"
        "nextcloud_announcements": {
            "installed_version": "3.0.0",
            "types": "logging",
            "enabled": "yes",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200"
        "notifications": {
            "types": "logging",
            "enabled": "yes"
        "oauth2": {
            "installed_version": "1.19.1",
            "enabled": "yes"
        "password_policy": {
            "enabled": "yes"
        "passwords": {
            "types": "",
            "enabled": "yes",
            "installed_version": "2025.10.20"
        "photos": {
            "types": "dav,authentication",
            "enabled": "yes",
            "lastPlaceMappedUser": "admin",
            "lastPlaceMappingDone": "true"
        "privacy": {
            "types": "",
            "enabled": "yes"
        "profile": {
            "installed_version": "1.0.0",
            "types": "",
            "enabled": "yes"
        "provisioning_api": {
            "enabled": "yes"
        "recognize": {
            "node_binary": "\/var\/www\/html\/custom_apps\/recognize\/bin\/node",
            "nice_binary": "\/usr\/bin\/nice",
            "installed_version": "9.0.7",
            "enabled": "yes"
        "recommendations": {
            "types": "",
            "enabled": "yes"
        "related_resources": {
            "types": "",
            "enabled": "yes"
        "serverinfo": {
            "types": "",
            "enabled": "yes",
            "size_appdata_storage": 0,
            "cached_count_appdata_files": 72,
            "cached_count_filecache": 139,
            "cached_count_storages": 6
        "settings": {
            "types": "",
            "enabled": "yes"
        "sharebymail": {
            "enabled": "yes"
        "sip_trip_phone": {
            "installed_version": "1.1.8",
            "types": "",
            "enabled": "yes"
        "socialsharing_telegram": {
            "installed_version": "3.3.0",
            "types": "",
            "enabled": "yes"
        "socialsharing_whatsapp": {
            "types": "",
            "enabled": "yes"
        "spreed": {
            "installed_version": "21.1.5",
            "types": "dav,prevent_group_restriction",
            "enabled": "yes",
            "signaling_token_privkey_es256": "***REMOVED SENSITIVE VALUE***",
            "signaling_token_pubkey_es256": "***REMOVED SENSITIVE VALUE***"
        "support": {
            "types": "session",
            "enabled": "yes"
        "survey_client": {
            "types": "",
            "enabled": "yes"
        "systemtags": {
            "installed_version": "1.21.1",
            "types": "logging",
            "enabled": "yes"
        "text": {
            "installed_version": "5.0.0",
            "types": "dav",
            "enabled": "yes"
        "theming": {
            "installed_version": "2.6.1",
            "types": "logging",
            "enabled": "yes"
        "twofactor_backupcodes": {
            "installed_version": "1.20.0",
            "types": "",
            "enabled": "yes"
        "updatenotification": {
            "types": "",
            "enabled": "yes",
            "update_check_errors": 0
        "user_status": {
            "installed_version": "1.11.0",
            "types": "",
            "enabled": "yes"
        "viewer": {
            "types": "",
            "enabled": "yes"
        "weather_status": {
            "types": "",
            "enabled": "yes"
        "webhook_listeners": {
            "installed_version": "1.2.0",
            "enabled": "yes"
        "whiteboard": {
            "installed_version": "1.3.0",
            "types": "",
            "enabled": "yes"
        "workflow_media_converter": {
            "installed_version": "1.15.1",
            "types": "",
            "enabled": "yes"
        "workflow_pdf_converter": {
            "enabled": "yes"
        "workflowengine": {
            "installed_version": "2.13.0",
            "enabled": "yes"
php occ app:list
  • activity: 4.0.0
  • app_api: 5.0.2
  • bookmarks: 15.2.0
  • bruteforcesettings: 4.0.0
  • calendar: 5.5.7
  • certificate24: 0.3.7
  • circles: 31.0.0
  • comments: 1.21.0
  • contactsinteraction: 1.12.0
  • context_chat: 4.5.0
  • cookbook: 0.11.4
  • dashboard: 7.11.0
  • dav: 1.33.0
  • facerecognition: 0.9.70
  • federation: 1.21.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • fileslibreofficeedit: 2.0.1
  • firstrunwizard: 4.0.0
  • impersonate: 2.0.0
  • integration_deepl: 2.0.0
  • logreader: 4.0.0
  • maps: 1.6.0
  • mediadc: 0.4.0
  • money: 0.30.0
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • passwords: 2025.10.20
  • photos: 4.0.0
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recognize: 9.0.7
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • sip_trip_phone: 1.1.8
  • socialsharing_telegram: 3.3.0
  • socialsharing_whatsapp: 3.3.0
  • spreed: 21.1.5
  • support: 3.0.0
  • survey_client: 3.0.0
  • systemtags: 1.21.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • whiteboard: 1.3.0
  • workflow_media_converter: 1.15.1
  • workflow_pdf_converter: 2.0.0
  • workflowengine: 2.13.0
  • admin_audit: 1.21.0
  • encryption: 2.19.0
  • files_external: 1.23.0
  • suspicious_login: 9.0.1
  • user_ldap: 1.22.0
