Hello!
I am using Nextcloud on my Windows 10 notebook (Lenovo ThinkPad E15 Gen.2). After installation, the battery drain increases sharply.
According to the statistics of Windows, 70% of the used power has been used by Nextcloud.
Is anything known about this? Is there anything I can test or change here?
For me it is very likely that the exreme battery usage is directly related to this issue. Maybe you can observe the CPU usage on your system and then add your observations to the existing issue…
