Hello
I’d like to use OneDrive as external storage. I tried to connect through WebDav but it doesn’t work and I don’t get an useful error message. I’m able to connect with the same credentials from my Windows Computer.
Any hints?
Thanks
Tim
Hello
Any hints?
Thanks
Tim
You can test the webdav capabilities of a storage with litmus:
https://forum.owncloud.org/viewtopic.php?t=21185
On your setup, do other webdav storages work?
thanks for your reply!
When I do this test against OneDrive it fails at the second test:
1. begin................. FAIL (Could not create new collection
/418dxxxxxxxx5e1b/litmus/’ for tests: 302 Found`
The same link with Windows (or in the browser) works though I get redirected to another link when I try it in the browser.
When I test against my nextcloud it fails at number 18 of the props test.
18. propget............... FAIL (Property {http://example.com/neon/litmus/}high-unicode had value , expected 𐀀)
Unfortunately I don’t have another webdav storage.
I’d rather like to access onedrive through their own rest API but I didn’t find a nextcloud plugin for that. Is there any plugin that gets near to the OneDrive API? (So I could code it by myself but I’d like to have an example.)
Can you retry with the redirected address? For a different webdav storage you could try demo.nextcloud.com
There is a feature request on owncloud: https://github.com/owncloud/core/issues/14478
Not sure, how the current status is, but if it is part in the open source part of owncloud, it probably can be ported to nextcloud.
I just successfully connected to the demo account. Connecting to the redirected URL didn’t work.
Thanks for your help anyway!
any news on onedrive implementation in nc?
I also need to know urgently whether it works with onedrive!
seems nobody’s is working on that implementation.
any news about onedrive storage working with nextcloud as external storage??
thanks
Seems like this is still not possible.
I tried to adapt these instructions here for Nextcloud, but it doesn’t work.
https://winscp.net/eng/docs/guide_microsoft_onedrive
Are there any news regarding OneDrive and Nextcloud?
