- Nextcloud Hub 26 Spring (35.0.1)
- Docker container on Ubuntu 26.04.1 aarch64
- where do I find this info?
nginx 1.31.6
- PHP version (e.g, 8.3):
8.5.11
no
the first time I tried an upload to the external storage
docker
no
It seems that uploading a large enough directory to the external storage fails: a considerable amount of files are transferred at the beginning, then it starts failing, and files that follow all fail. The same does not seem to happen if I upload to the regular nextcloud storage.
The external storage is simply a local directory, on the same hard disk, mounted as a volume in the docker container.
It seems like the external storage disconnected: but can local directory disconnect?
Create the external storage setup (local directory).
Upload a “large” directory from the web interface (but also happens with the Android client).
Wait a bit: many files a transferred properly but, at a certain point, it starts failing. This is not 100% deterministic, but I can reproduce pretty quickly.
Keep in mind that this is a slow aarch64 device.
I reproduced the problem several times, and I could generate failure logs. However, it seems I could generate different types of errors. I provide a few examples, but please note that the same error is typically replicated multiple times for each file that fails and the output is huge. I try to provide only single lines here:
{"reqId":"ifU0id6ODOBmHAVLOWBh","level":3,"time":"2026-10-07T19:40:05+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/luca/albums/Camera_20250101/20241231_214040.jpg","scriptName":"/remote.php","message":"File with id "209749" has not been found.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/154.0.0.0 Safari/537.36","version":"35.0.1.1","exception":{"Exception":"OCP\Files\NotFoundException","Message":"File with id "209749" has not been found.","Code":0,"Trace":[{"file":"/var/www/html/apps/activity/lib/FilesHooks.php","line":683,"function":"getPath","class":"OC\Files\View","type":"->","args":[209749]},{"file":"/var/www/html/apps/activity/lib/FilesHooks.php","line":150,"function":"getSourcePathAndOwner","class":"OCA\Activity\FilesHooks","type":"->","args":["/albums/Camera_20250101/20241231_214040.jpg"]},{"file":"/var/www/html/apps/activity/lib/FilesHooks.php","line":88,"function":"addNotificationsForFileAction","class":"OCA\Activity\FilesHooks","type":"->","args":["/albums/Camera_20250101/20241231_214040.jpg","file_created","created_self","created_by"]},{"file":"/var/www/html/apps/activity/lib/FilesHooksStatic.php","line":24,"function":"fileCreate","class":"OCA\Activity\FilesHooks","type":"->","args":["/albums/Camera_20250101/20241231_214040.jpg"]},{"file":"/var/www/html/lib/private/legacy/OC_Hook.php","line":87,"function":"fileCreate","class":"OCA\Activity\FilesHooksStatic","type":"::","args":[{"path":"/albums/Camera_20250101/20241231_214040.jpg"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":465,"function":"emit","class":"OC_Hook","type":"::","args":["OC_Filesystem","post_create",{"path":"/albums/Camera_20250101/20241231_214040.jpg"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":408,"function":"emitPostHooks","class":"OCA\DAV\Connector\Sabre\File","type":"->","args":[false]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","line":352,"function":"finalizeUpload","class":"OCA\DAV\Connector\Sabre\File","type":"->","args":[{"class":"OCA\Files_Trashbin\Storage","cache":{"class":"OC\Files\Cache\Cache"},"scanner":{"class":"OC\Files\Cache\Scanner"},"watcher":"*** sensitive parameters replaced ","propagator":{"class":"OC\Files\Cache\Propagator"},"updater":{"class":"OC\Files\Cache\Updater"}},"Camera_20250101/20241231_214040.jpg",false,{"class":"OC\Files\View"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":129,"function":"put","class":"OCA\DAV\Connector\Sabre\File","type":"->","args":[" sensitive parameters replaced "]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\DAV\Connector\Sabre\Directory","type":"->","args":[" sensitive parameters replaced "]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\DAV\Server","type":"->","args":[" sensitive parameters replaced "]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\DAV\CorePlugin","type":"->","args":[{"class":"Sabre\HTTP\Request"},{"class":"Sabre\HTTP\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\DAV\Server","type":"->","args":["method:PUT",[{"class":"Sabre\HTTP\Request"},{"class":"Sabre\HTTP\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":216,"function":"invokeMethod","class":"Sabre\DAV\Server","type":"->","args":[{"class":"Sabre\HTTP\Request"},{"class":"Sabre\HTTP\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":436,"function":"start","class":"OCA\DAV\Connector\Sabre\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\DAV\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":158,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require"},{"file":"/var/www/html/lib/OC.php","line":1397,"function":"{closure:/var/www/html/remote.php:102}","args":[" sensitive parameters replaced "]},{"file":"/var/www/html/remote.php","line":102,"function":"handleRequests","class":"OC","type":"::","args":[{"class":"Closure"}]}],"File":"/var/www/html/lib/private/Files/View.php","Line":1870,"message":"File with id "209749" has not been found.","CustomMessage":"File with id "209749" has not been found."}}
Another log I found:
{"reqId":"twJVpErceBBUhde5LIcP","level":3,"time":"2026-10-07T21:50:13+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PUT","url":"/remote.php/dav/uploads/luca/web-file-upload-407e225fce98a6c4/14","scriptName":"/remote.php","message":"Expected filesize of 104857600 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 15646720 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/154.0.0.0 Safari/537.36","version":"35.0.1.1","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 104857600 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 15646720 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":129,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Upload/UploadFolder.php","line":33,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":216,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":436,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":158,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require"},{"file":"/var/www/html/lib/OC.php","line":1397,"function":"{closure:/var/www/html/remote.php:102}","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/remote.php","line":102,"function":"handleRequests","class":"OC","type":"::","args":[{"__class__":"Closure"}]}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","Line":276,"message":"Expected filesize of 104857600 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 15646720 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","CustomMessage":"Expected filesize of 104857600 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 15646720 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side."}}
In another case, instead, files seemed to be properly copied (no error is shown), but then I could not navigate in the external storage:
{"reqId":"vvoy8E5Pg4VFy0MySz08","level":1,"time":"2026-10-09T22:30:43+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/luca/albums/","scriptName":"/remote.php","message":"The app config key dav/enableCalendarFederation is not defined in the config lexicon","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/155.0.0.0 Safari/537.36","version":"35.0.1.1","data":[]}
{"reqId":"vvoy8E5Pg4VFy0MySz08","level":1,"time":"2026-10-09T22:30:43+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/luca/albums/","scriptName":"/remote.php","message":"The app config key dav/sendInvitations is not defined in the config lexicon","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/155.0.0.0 Safari/537.36","version":"35.0.1.1","data":[]}
{"reqId":"vvoy8E5Pg4VFy0MySz08","level":1,"time":"2026-10-09T22:30:43+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/luca/albums/","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/155.0.0.0 Safari/537.36","version":"35.0.1.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /albums could not be located","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php","line":86,"function":"getNodeForPath","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["albums"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":971,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->","args":["files/luca/albums"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1664,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->","args":["files/luca/albums",["{DAV:}getcontentlength","{DAV:}getcontenttype","{DAV:}getetag","{DAV:}getlastmodified","{DAV:}creationdate","And 34 more entries, set log level to debug to see all entries"],1]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1649,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\Xml\\Writer","elementMap":[],"contextUri":"/remote.php/dav/","namespaceMap":{"DAV:":"d","http://sabredav.org/ns":"s","http://owncloud.org/ns":"oc","http://nextcloud.org/ns":"nc"},"classMap":[]},{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":216,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":436,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":158,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require"},{"file":"/var/www/html/lib/OC.php","line":1397,"function":"{closure:/var/www/html/remote.php:102}","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/remote.php","line":102,"function":"handleRequests","class":"OC","type":"::","args":[{"__class__":"Closure"}]}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","Line":541,"message":"Uncaught exception","CustomMessage":"Uncaught exception"}}
{"reqId":"Lpb01W16EpG24jOhf9HB","level":1,"time":"2026-10-09T22:30:52+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/luca/albums/","scriptName":"/remote.php","message":"The app config key dav/enableCalendarFederation is not defined in the config lexicon","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/155.0.0.0 Safari/537.36","version":"35.0.1.1","data":[]}
{"reqId":"Lpb01W16EpG24jOhf9HB","level":1,"time":"2026-10-09T22:30:52+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/luca/albums/","scriptName":"/remote.php","message":"The app config key dav/sendInvitations is not defined in the config lexicon","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/155.0.0.0 Safari/537.36","version":"35.0.1.1","data":[]}
{"reqId":"Lpb01W16EpG24jOhf9HB","level":1,"time":"2026-10-09T22:30:52+00:00","remoteAddr":"192.168.0.1","user":"luca","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/luca/albums/","scriptName":"/remote.php","message":"Uncaught exception","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/155.0.0.0 Safari/537.36","version":"35.0.1.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /albums could not be located","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Tree.php","line":86,"function":"getNodeForPath","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["albums"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":971,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->","args":["files/luca/albums"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1664,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->","args":["files/luca/albums",["{DAV:}getcontentlength","{DAV:}getcontenttype","{DAV:}getetag","{DAV:}getlastmodified","{DAV:}creationdate","And 34 more entries, set log level to debug to see all entries"],1]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1649,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\Xml\\Writer","elementMap":[],"contextUri":"/remote.php/dav/","namespaceMap":{"DAV:":"d","http://sabredav.org/ns":"s","http://owncloud.org/ns":"oc","http://nextcloud.org/ns":"nc"},"classMap":[]},{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":216,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":436,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":25,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":158,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require"},{"file":"/var/www/html/lib/OC.php","line":1397,"function":"{closure:/var/www/html/remote.php:102}","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/remote.php","line":102,"function":"handleRequests","class":"OC","type":"::","args":[{"__class__":"Closure"}]}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","Line":541,"message":"Uncaught exception","CustomMessage":"Uncaught exception"}}
After a minute, the external storage is available again.
Not sure if this is related, but in the logs I always have hundreds of errors from Nextcloud Memories on the same external storage:
Failed to index folder /luca/files/albums: Local storage path does not exist "/albums/"
I doubt this is related to the web interface. Other clients show the same behavior.
The reverse proxy shows 200 until the transfer works, then it starts with 404. In some cases I see 499.
"forwarded_for_headers": [
"HTTP_X_FORWARDED_FOR"
"overwrite.cli.url": "https:\/\/...",
"overwriteprotocol": "https",
"dbtype": "mysql",
"version": "35.0.1.1",
"theme": "",
"logfile": "\/var\/log\/nextcloud.log",
"loglevel": 1,
"memories.exiftool": "\/var\/www\/html\/apps\/memories\/bin-ext\/exiftool-aarch64-glibc",
"memories.vod.path": "\/var\/www\/html\/apps\/memories\/bin-ext\/go-vod-aarch64",
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpstreamoptions": {
"ssl": {
"allow_self_signed": false,
"verify_peer": true,
"verify_peer_name": true
"config_preset": 2,
"mail_smtpauth": true,
"mail_smtpport": "587",
"twofactor_enforced": "true",
"admin",
"guest_app"
"mysql.utf8mb4": true,
"enable_previews": true,
"preview_concurrency_new": 1,
"preview_concurrency_all": 2,
"enabledPreviewProviders": [
"OC\\Preview\\Image",
"OC\\Preview\\HEIC",
"OC\\Preview\\TIFF",
"OC\\Preview\\Movie"
"preview_max_x": 2048,
"preview_max_y": 2048,
"preview_max_memory": 500,
"app_install_overwrite": [
"news"
Any idea why external storage seems to be unstable?
Thanks!
