Hi!) I created folders for files from user www-data via command
sudo -u www-data bash in folder on my external storage and than move files to that folders - files showed in folders by itself, but!!!
After that uploading speed only on External storage became drammaticfy slow, and I can not do anything with this files - exept open and download them
Nextcloud Server 31 Ubuntu 22.04.5 Apache, installation in folder /var/www/nextcloud
For example
{"reqId":"toElXwuO6S5Zs3uMvDeO","level":3,"time":"2025-04-21T14:58:07+03:00","remoteAddr":"37.228.90.158","user":"nextcloud-admin","app":"webdav","method":"PUT","url":"/remote.php/dav/files/nextcloud-admin/CV/RT-AX88U_3004_388.9_0/RT-AX88U_3004_388.9_0_ubi.w","message":"Error while copying file to target location (copied: -1 bytes, expected filesize: 83099668 bytes)","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:137.0) Gecko/20100101 Firefox/137.0","version":"31.0.1.2","exception":{"Exception":"Sabre\\DAV\\Exception","Message":"Error while copying file to target location (copied: -1 bytes, expected filesize: 83099668 bytes)","Code":0,"Trace":[{"file":"/var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/Server.php","line":1137,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->"},{"file":"/var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":492,"function":"updateFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/oblako.stratim/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/oblako.stratim/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/oblako.stratim/apps/dav/lib/Connector/Sabre/Server.php","line":49,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/oblako.stratim/apps/dav/lib/Server.php","line":397,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/oblako.stratim/apps/dav/appinfo/v2/remote.php","line":21,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/oblako.stratim/remote.php","line":145,"args":["/var/www/oblako.stratim/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/oblako.stratim/apps/dav/lib/Connector/Sabre/File.php","Line":240,"message":"Error while copying file to target location (copied: -1 bytes, expected filesize: 83099668 bytes)","exception":[],"CustomMessage":"Error while copying file to target location (copied: -1 bytes, expected filesize: 83099668 bytes)"},"id":"680636601843b"}
External storage mount as local without credentials - just point to folder path on host
And status for folders that i created by user www-data is Pending but folder that I’ve created from root and give permissions for user www-data shows OK
