Hi everyone, I am working on setting up my NAS using OMV and nextcloud. I am on a raspberry pi4 and have enables the external storage option. I am losing it when I try to add my 2TB external hard drive.
I am selecting local (I am getting the error that smb/cifs cannot be used, so I do not know if that is part of it), but I think I am putting in the location incorrectly. I have been using the absolute path and it kicks back as incorrect everytime. I am sure I am missing an easy step, but I am at a loss.
Any help you all could give would be amazing. Thanks so much!
This is my first time using NextCloud, but this is what I did to add an SMB/CIFS drive. It mounts properly and and is viewable by the specific user. That said it “mostly” works from what I can tell. Curious to see if you observe similar behavior.
My Testing is a follows :
Upload large file (1 GB Movie) (drag and drop via Chrome browser) - WORKS
Upload folder of MP3s (80MB) (drag and drop via Chrome browser) - 50% of files transferred
Upload folder of MP3s (80MB) to NextCloud Default drive (drag and drop via Chrome browser) - WORKS
Upload folder of MP3s (80MB) (drag and drop via Opera browser) - 50% of files transferred
Upload folder of MP3s (100MB) (via Android Phone NextCloud app) - WORKS
Upload folder of pictures (90MB) via Android Phone NextCloud app) - WORKS
When I loaded the docker image, I needed to set the absolute path in the volumes and then where to reference it through after the colon. So it looks like this:
