Nextcloud version: 22.2.3
Operating system and version: Debian 10
Apache version : Apache 2.4.38
PHP version: 7.4.27
Only 1 external storage works, others with the exact same configuration fail.
I have 5 NFS mounts, hosted on the same NAS, with the exact same permissions, exact same base path, no contents in them whatsoever, but only 1 of these mounts work as external storage. The others do not allow me to upload any files. When I try do to so, I just get a small “forbidden” message popup.
Permissions on all of the 5 moutns:
drwxr-x--- 7 www-data www-data
Is this the first time you’ve seen this error?: No, I’ve attempted this before, but then none worked
- Mount NFS mount
- Add external storage as type local
- Try to upload files
Nothing, no nextcloud logs get created
Unable to find anything significant in the apache2 error or access logs
As all 5 mounts are exactly the same, except for their name, what could be causing this?
