External Storage Not Connecting - Updated to 22.2.3
Updated to Version 22.2.3 today. After completing the update my external storage devices no longer connect.
This happened straight after upgrading from the previous version and seems to relate to “Icewind”.
I have manged to fix this before by replacing the “icewind” folder from Version 22.0, however no such luck this time.
Exception: Class 'Icewind\SMB\BasicAuth' not found
/config/www/nextcloud/lib/private/AppFramework/App.php - line 156:
/config/www/nextcloud/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main()
/config/www/nextcloud/lib/base.php - line 1006:
OC\Route\Router->match()
/config/www/nextcloud/index.php - line 36:
OC::handleRequest()
Caused by Error: Class 'Icewind\SMB\BasicAuth' not found
/config/www/nextcloud/apps/files_external/lib/Controller/StoragesController.php - line 250:
OCA\Files_External\Lib\Backend\SMB->manipulateStorageConfig()
/config/www/nextcloud/apps/files_external/lib/Controller/StoragesController.php - line 264:
OCA\Files_External\Controller\StoragesController->manipulateStorageConfig()
/config/www/nextcloud/apps/files_external/lib/Controller/StoragesController.php - line 346:
OCA\Files_External\Controller\StoragesController->updateStorageStatus("*** sensiti ... *")
/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 217:
OCA\Files_External\Controller\StoragesController->show()
/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 126:
OC::handleRequest()
{"reqId":"l3QUutckO0Hg4d2eIqcE","level":3,"time":"2021-12-05T19:06:02+00:00","remoteAddr":"172.18.0.5","user":"admin","app":"index","method":"GET","url":"/apps/files_external/globalstorages/11?testOnly=true","message":"Class 'Icewind\\SMB\\BasicAuth' not found","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36","version":"22.2.3.0","exception":{"Exception":"Exception","Message":"Class 'Icewind\\SMB\\BasicAuth' not found","Code":0,"Trace":[{"file":"/config/www/nextcloud/lib/private/AppFramework/App.php","line":156,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/config/www/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/config/www/nextcloud/lib/base.php","line":1006,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/config/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":158,"Previous":{"Exception":"Error","Message":"Class 'Icewind\\SMB\\BasicAuth' not found","Code":0,"Trace":[{"file":"/config/www/nextcloud/apps/files_external/lib/Controller/StoragesController.php","line":250,"function":"manipulateStorageConfig","class":"OCA\\Files_External\\Lib\\Backend\\SMB","type":"->"},{"file":"/config/www/nextcloud/apps/files_external/lib/Controller/StoragesController.php","line":264,"function":"manipulateStorageConfig","class":"OCA\\Files_External\\Controller\\StoragesController","type":"->"},{"file":"/config/www/nextcloud/apps/files_external/lib/Controller/StoragesController.php","line":346,"function":"updateStorageStatus","class":"OCA\\Files_External\\Controller\\StoragesController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":217,"function":"show","class":"OCA\\Files_External\\Controller\\StoragesController","type":"->"},{"file":"/config/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":126,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/config/www/nextcloud/lib/private/AppFramework/App.php","line":156,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/config/www/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/config/www/nextcloud/lib/base.php","line":1006,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/config/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/config/www/nextcloud/apps/files_external/lib/Lib/Backend/SMB.php","Line":79},"CustomMessage":"--"},"id":"61ad0d9feb837"}
This is a workaround. This can be a temporary fix until the developers solve the real issue. Are they aware of this problem?
Have you enabled the external storage app, and perhaps disabled and enabled again to make sure it’s the current version?
Found a similar topic: Nextcloud error external smb storage
Not sure if the developers are aware.
The other post you have found looks like a similar problem and others on the Unraid forum have had the same problem, but have worked around it as I have described:
https://forums.unraid.net/topic/48383-support-linuxserverio-nextcloud/?do=findComment&comment=975142
I have tried enabling and disabling the app, as well replacing the app files completely with new files from that of a fresh download - all with no luck.
Looks like I might have to restore my back up :frowning:
