I got this crazy problem. During the weekend we mover our NC 23.0.0 from a low performance server to a faster server.
We did an SQL dump and copied the data folded to the new server after we done a new install on the new server i.e. an NC 23.0.0 1 to 1 move. Everything worked perfectly.
Except external storage set up! Wehn I go in to the external storage setup as admin, I’m getting an error pave saying, “Internal server error” AND it shows the old servers IP! I recon that’s the problem, but finding where to change the IP? Anyone else seen this issue?
Can you export configuration as JSON via files_external:export put correct IP address there and put it back via files_external:import?
Because I do not really understand what kind of IP you mean… You connected to external Storage via IP directly?
