External storage: How to mount permanently?
Hi all,
CASE: (Changed after more research and experience)
My Nextcloud is on a VPS I have rented at Hetzner. The VPS only comes with 40GB of storage (including the nextcloud installation) so in order to have enough space, I have also rented a 1TB Storage Box from Hetzner. I have figured out how to mount the storage box to Nextclouds data directory by use of SFTP, but I don’t know how to make this permanent. As I understand, I have to add some commands to fstab, but I cannot find the relevan tinformation
QUESTION:
How can I figure out which command will work, and where can I find the necessary information?
/Jacob
Nextcloud Hub 10 (31.0.4)
YunoHost 12.0.12 (linux, stable)
Hetzner Cloud (VPS)
Hetzner Storage Box (external storage)
