example
Nextcloud version (eg, 20.0.5): 23.0.0
Operating system and version (eg, Ubuntu 20.04): CentOS Linux 7 (Core) Kernel 5.4.157-1-pve on an x86_64
Apache or nginx version (eg, Apache 2.4.25): apache
PHP version (eg, 7.4): PHP 7.4.27
When opening a directory that has 1000 folders or more in it it errors and log shows above. It happens in any directory that has large amount of folders/files.
The directory is mounted with external drive over smb
Is this the first time you’ve seen this error? (Y/N):Y
- navigate from login to files> then goto folder that has large amount of items
{"reqId":"Yk8GCeRB0@iKKKw8uKc8FgAAAAg","level":4,"time":"2022-04-07T15:40:58+00:00","remoteAddr":"172.16.255.254","user":"mparker","app":"webdav","method":"PROPFIND","url":"/remote.php/dav/files/mparker/S%20Drive/Mozaic/Interfaces/Customers/AMAZON.COM/archive/in","message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1 too many SQL variables","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36","version":"23.0.0.10","exception":{"Exception":"OC\\DB\\Exceptions\\DbalException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1 too many SQL variables","Code":1,"Trace":[{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":302,"function":"wrap","class":"OC\\DB\\Exceptions\\DbalException","type":"::"},{"file":"/var/www/nextcloud/lib/private/Comments/Manager.php","line":661,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":88,"function":"getNumberOfUnreadCommentsForObjects","class":"OC\\Comments\\Manager","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":116,"function":"cacheDirectory","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1646,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":339,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/Exceptions/DbalException.php","Line":71,"Previous":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1 too many SQL variables","Code":1,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1780,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\SQLite\\ExceptionConverter","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1719,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1067,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":236,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":287,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":300,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Comments/Manager.php","line":661,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":88,"function":"getNumberOfUnreadCommentsForObjects","class":"OC\\Comments\\Manager","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":116,"function":"cacheDirectory","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1646,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":339,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/SQLite/ExceptionConverter.php","Line":82,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[HY000]: General error: 1 too many SQL variables","Code":1,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":75,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1054,"function":"prepare","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":236,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":287,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":300,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Comments/Manager.php","line":661,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":88,"function":"getNumberOfUnreadCommentsForObjects","class":"OC\\Comments\\Manager","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":116,"function":"cacheDirectory","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1646,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":339,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 1 too many SQL variables","Code":"HY000","Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":70,"function":"prepare","class":"PDO","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1054,"function":"prepare","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":236,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":287,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":300,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/Comments/Manager.php","line":661,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":88,"function":"getNumberOfUnreadCommentsForObjects","class":"OC\\Comments\\Manager","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php","line":116,"function":"cacheDirectory","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"handleGetProperties","class":"OCA\\DAV\\Connector\\Sabre\\CommentPropertiesPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1661,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1646,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":339,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","Line":70}}},"CustomMessage":"--"},"id":"624f0a3c9b2d8"}
[webdav] Fatal: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1 too many SQL variables
PROPFIND /remote.php/dav/files/mparker/S%20Drive/Mozaic/Interfaces/Customers/AMAZON.COM/archive/in
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
