- Nextcloud Server version :
Hub 10: 31.0.6 - Operating system and version:
Linux, Arch - Web server and version :
NGINX - PHP version:
8.3 - Is this the first time you’ve seen this error?
YES - When did this problem seem to first start?
CONSTANT - Installation method:
NCP - Are you using CloudfIare, mod_security, or similar?
NO
An external site I wish to embed will not display correctly. Nextcloud’s top bar menu is hiding the site’s menu. Looking for help on how to get the site’s coding to display correctly with nextcloud.
- Added link for external site I wish to embed, to be displayed in NC top bar menu.
- Click on newly created link
- Site opens embedded, but it’s own top most menu is obscured by NC top bar menu.
- My other external, embedded sites DO display correctly in NC.
Please provide the log entries from your Nextcloud log:
Not Applicable. Not a NextCloud 'error' really.
Issue is browser agnostic. Regardless of browser used. The NextCloud somehow removes the menu from Bibledit, and I don't know why it does that.
The original menu looks like this:
<div id="topbar" class="menu-advanced">
<span class="nowrap"><a href="/index/index?item=translate" title="Verse editor | Notes | Resources | User resources | Feedback">Translate</a></span>
<span class="nowrap"><a href="/index/index?item=search" title="Search | Advanced search | Search all Bibles and notes | Search Bible for similar verses | Search Bible for similar Strong's numbers | Search Bible for Strong's number | Search Bible for similar Hebrew or Greek words">Search</a></span>
<span class="nowrap"><a href="/index/index?item=tools" title="Changes">Tools</a></span>
<span class="nowrap"><a href="/index/index?item=settings" title="Account | Basic mode | Logout | Notifications | Preferences">Settings</a></span>
<span class="nowrap"><a href="/menu/index?item=help/index" title="Help">Help</a></span>
<div class="clearfix"></div>
</div>
When embedding this in NextCloud, it reduces the original menu to this:
<div id="topbar" class="menu-advanced"></div>
That explains why it displays nothing: all menu items have been removed.
I wonder if there's an option in NextCloud to remove menus like this, or an option to not disturb the embedded website?
The original menu has "href="/index/index?" multiple times. Possibly NextCloud does not like the "href" attributes?
"openbiblefoundation.org",
"cloud.openbiblefoundation.org"
"dbtype": "mysql",
"version": "31.0.6.2",
"overwrite.cli.url": "https:\/\/openbiblefoundation.org",
"dbport": "",
"mysql.utf8mb4": true,
"default_phone_region": "US",
"opcache.memory_consumption": 256,
"opcache.interned_strings_buffer": 32,
"loglevel": 2,
"allow_local_remote_servers": "true",
"skeletondirectory": "core\/obf-skeleton",
"app.mail.attachment-size-limit": "3*1024*1024",
"app.mail.imap.timeout": 20,
"app.mail.smtp.timeout": 20,
"app.mail.sieve.timeout": 20,
"app.mail.verify-tls-peer": "false",
"app.mail.background-sync-interval": 3600,
"mail_smtpmode": "smtp",
"mail_sendmailmode": "pipe",
"mail_smtpport": "587",
"filelocking.enabled": true,
"redis": {
"port": 6379,
"timeout": 0,
"memories.exiftool": "\/var\/www\/nc\/apps\/memories\/bin-ext\/exiftool-aarch64-glibc",
"memories.vod.path": "\/var\/www\/nc\/apps\/memories\/bin-ext\/go-vod-aarch64",
"app_install_overwrite": {
"0": "news",
"1": "radio",
"2": "talked",
"3": "backup",
"4": "files_scripts",
"5": "files_rightclick",
"6": "cms_pico",
"7": "breezedark",
"8": "apporder",
"10": "login_notes",
"11": "maps",
"12": "nextframe"
"theme": "",
"mail_smtpauth": true,
"defaultapp": "",
"enforce_theme": "dark",
"mail_smtppassword": "***REMOVED SENSITIVE VALUE***"
- activity: 4.0.0
- admin_audit: 1.21.0
- announcementcenter: 7.1.3
- app_api: 5.0.2
- appointments: 2.4.5
- apporder: 0.15.0
- approval: 2.2.0
- bookmarks: 15.1.0
- breezedark: 29.0.0
- calendar: 5.3.2
- circles: 31.0.0
- comments: 1.21.0
- contacts: 7.1.3
- contactsinteraction: 1.12.0
- dashboard: 7.11.0
- dav: 1.33.0
- deck: 1.15.1
- external: 6.0.2
- federation: 1.21.0
- files: 2.3.1
- files_accesscontrol: 2.0.0
- files_automatedtagging: 2.0.0
- files_downloadlimit: 4.0.0
- files_external: 1.23.0
- files_lock: 31.0.2
- files_pdfviewer: 4.0.0
- files_reminders: 1.4.0
- files_scripts: 4.1.0
- files_sharing: 1.23.1
- files_trashbin: 1.21.0
- files_versions: 1.24.0
- fileslibreofficeedit: 2.0.1
- firstrunwizard: 4.0.0
- forms: 5.1.0
- groupfolders: 19.1.0
- htmlviewer: 31.0.0
- login_notes: 1.6.1
- logreader: 4.0.0
- mail: 5.1.3
- maps: 1.5.0
- memories: 7.5.2
- news: 26.0.1
- nextframe: 0.0.7
- notes: 4.12.1
- notifications: 4.0.0
- oauth2: 1.19.1
- password_policy: 3.0.0
- passwords: 2025.5.11
- phonetrack: 0.8.2
- photos: 4.0.0-dev.1
- polls: 7.4.4
- privacy: 3.0.0
- profile: 1.0.0
- provisioning_api: 1.21.0
- recognize: 9.0.1
- recommendations: 4.0.0
- registration: 2.7.0
- related_resources: 2.0.0
- richdocuments: 8.7.1
- richdocumentscode_arm64: 25.4.202
- serverinfo: 3.0.0
- settings: 1.14.0
- sharebymail: 1.21.0
- side_menu: 5.1.1
- spreed: 21.1.0
- support: 3.0.0
- survey_client: 3.0.0
- suspicious_login: 9.0.1
- systemtags: 1.21.1
- tasks: 0.16.1
- terms_of_service: 4.4.0
- text: 5.0.0
- theming: 2.6.1
- theming_customcss: 1.18.0
- unroundedcorners: 1.1.4
- updatenotification: 1.21.0
- user_status: 1.11.0
- viewer: 4.0.0
- weather_status: 1.11.0
- webhook_listeners: 1.2.0
- workflow_script: 2.0.0
- workflowengine: 2.13.0
Disabled: - bruteforcesettings: 4.0.0 (installed 2.9.0)
- encryption: 2.19.0
- user_ldap: 1.22.0
