A couple questions around the external S3 storage options.
is it possible to mount a folder under a bucket instead of just the root of the bucket? We have 1 bucket with user directories underneath the root, and S3 security at the folder level. Would be nice to have the same folder mounted for specific users in next cloud.
Is is possible to send the encryption headers to S3 so that the files are encrypted at rest on the S3 storage.
