Nextcloud version: 20.0.7
Operating system and version Ubuntu 20.04)
on Linux 5.11.0-25-generic x86_64
Apache or nginx version: 2.4.41
PHP version 7.4.3
System Report URL: Collective Cloud
External mounted drive reverted to a state of files from 3 months ago. I am using Nextcloud to host files from a local mounted 4TB hard drive at a mount location of /mnt/torrinshared and then configured through “External storages”. This has been running great for the past 3 months and have 3 separate external storages mounted in similar fashion. (only using one HDD here as the example where i’ve lost over 300GB of data).
Now, this morning sometime, all 3 of the hard drives lost all files between May 26th 2021 and today, August 13th 2021. Each hard drive seems to have reverted back to a state where the files all have timestamps of May 26th, 2021. I have 3 other hard drives locally mounted and configured in Nextcloud the same way and they all experienced this behaviour. I have ruled out hard drive failures as this has occurred across 3 independent hard drives. And have ruled out a backup causing this issue from my Virtualmin instance that my Nextcloud instance is running on.
Anybody else experience this or know what is going on?
Is this the first time you’ve seen this error? (Y/N): Yes
- None, happened by itself.
Attached here: https://drive.google.com/file/d/1r7qFnOm-8z78yUgCfRAtAeMcvPmUi28L/view?usp=sharing
'instanceid' => 'XXXXXXXXXXX',
'passwordsalt' => 'XXXXXXXXXXX',
'secret' => 'XXXXXXXXXXX',
0 => 'XXXXXXXXXXX',
'datadirectory' => '/home/cloud/public_html/data',
'version' => '20.0.7.1',
'overwrite.cli.url' => 'XXXXXXXXXXX',
'dbname' => 'XXXXXXXXXXX',
'dbhost' => 'XXXXXXXXXXX',
'dbport' => 'XXXXXXXXXXX',
'dbuser' => 'XXXXXXXXXXX',
'dbpassword' => 'XXXXXXXXXXX',
'log_type' => 'file',
'logfile' => 'logs/nextcloud.log',
'loglevel' => '2',
'mail_domain' => 'XXXXXXXXXXX',
'mail_smtpmode' => 'XXXXXXXXXXX',
'mail_smtpauthtype' => 'PLAIN',
'mail_sendmailmode' => 'XXXXXXXXXXX',
'mail_from_address' => 'XXXXXXXXXXX',
'mail_smtphost' => 'XXXXXXXXXXX',
'mail_smtpport' => 'XXXXXXXXXXX',
'app_install_overwrite' =>
0 => 'mindmap_app',
1 => 'ocr',
2 => 'files_clipboard',
3 => 'bookmarks_fulltextsearch',
'mail_smtpauth' => 1,
'mail_smtpsecure' => 'tls',
'mail_smtpname' => 'XXXXXXXXXXX',
'mail_smtppassword' => 'XXXXXXXXXXX',
https://drive.google.com/file/d/1pgnIfdILXVN5yml1B9FO4WM73cJNqU8i/view?usp=sharing
