i use nextcloud 17.0.2 on freenas latest version system.
I installed the plugin for external archives on nextcloud.
This message appears: ââ FTP support in PHP is not enabled or installed. Unable to mount âFTPâ. Ask your system administrator to install it.
âsmbclientâ is not installed. Unable to mount âSMB / CIFSâ, âSMB / CIFS using OC credentialsâ. Ask your system administrator to install it. "
I tried to solve the FTP problem and found in the nextcloud documentation: "Notes
The external FTP / FTPS storage needs the allow_url_fopen PHP setting to be set to 1. When having connection problems make sure it is not set to 0 in your php.ini. See PHP Version and Information to learn how to find the right php.ini file to edit. "
i found my php.ini in /usr/local/etc/php.ini.
my allow_url_fopen is set correctly ⊠so I donât understand how I can enable my php.
and to enable SMB ?
Can you help me? thanks.
PHP_VER=71
PHP_VERSION=7.1.32
My php.ini:
