Running the example docker compose script provided by Nextcloud returns the following error:
Creating nextcloud_db_1 ... done
Creating nextcloud_app_1 ... done
Creating nextcloud_web_1 ...
ERROR: for nextcloud_web_1 a bytes-like object is required, not 'str'
ERROR: for web a bytes-like object is required, not 'str'
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 261, in _raise_for_status
response.raise_for_status()
File "/usr/lib/python3/dist-packages/requests/models.py", line 940, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: http+docker://localhost/v1.22/containers/9067680bc0aec19af7192b56675c713f9a2b5f97b72120fc6d7fbc93e213613f/start
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/compose/service.py", line 625, in start_container
container.start()
File "/usr/lib/python3/dist-packages/compose/container.py", line 241, in start
return self.client.start(self.id, **options)
File "/usr/lib/python3/dist-packages/docker/utils/decorators.py", line 19, in wrapped
return f(self, resource_id, *args, **kwargs)
File "/usr/lib/python3/dist-packages/docker/api/container.py", line 1095, in start
self._raise_for_status(res)
File "/usr/lib/python3/dist-packages/docker/api/client.py", line 263, in _raise_for_status
raise create_api_error_from_http_exception(e)
File "/usr/lib/python3/dist-packages/docker/errors.py", line 31, in create_api_error_from_http_exception
raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 400 Client Error: Bad Request ("b'OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: rootfs_linux.go:76: mounting "/run/desktop/mnt/host/wsl/docker-desktop-bind-mounts/Ubuntu-20.04/c847f57279f05e17c5118010ad8b04a6cfc03ef4e0f603e89056a71c4f06c594" to rootfs at "/etc/nginx/nginx.conf" caused: mount through procfd: not a directory: unknown: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type'")
File "/usr/bin/docker-compose", line 11, in <module>
load_entry_point('docker-compose==1.25.0', 'console_scripts', 'docker-compose')()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 72, in main
command()
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 128, in perform_command
handler(command, command_options)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1107, in up
to_attach = up(False)
File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1088, in up
return self.project.up(
File "/usr/lib/python3/dist-packages/compose/project.py", line 565, in up
results, errors = parallel.parallel_execute(
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 112, in parallel_execute
raise error_to_reraise
File "/usr/lib/python3/dist-packages/compose/parallel.py", line 210, in producer
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/project.py", line 548, in do
return service.execute_convergence_plan(
File "/usr/lib/python3/dist-packages/compose/service.py", line 545, in execute_convergence_plan
return self._execute_convergence_create(
File "/usr/lib/python3/dist-packages/compose/service.py", line 460, in _execute_convergence_create
containers, errors = parallel_execute(
result = func(obj)
File "/usr/lib/python3/dist-packages/compose/service.py", line 465, in <lambda>
lambda service_name: create_and_start(self, service_name.number),
File "/usr/lib/python3/dist-packages/compose/service.py", line 457, in create_and_start
self.start_container(container)
File "/usr/lib/python3/dist-packages/compose/service.py", line 627, in start_container
if "driver failed programming external connectivity" in ex.explanation:
TypeError: a bytes-like object is required, not 'str'
For reference, here’s the docker-compose.yaml I’m running:
version: '2'
volumes:
nextcloud:
db:
services:
db:
image: mariadb
restart: always
volumes:
- db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=*
- MYSQL_PASSWORD=*
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
image: nextcloud:fpm
restart: always
links:
- db
volumes:
- nextcloud:/var/www/html
environment:
- MYSQL_PASSWORD=*
- MYSQL_HOST=db
web:
image: nginx
restart: always
ports:
- 8080:80
links:
- app
volumes:
- ./nginx.conf:/etc/nginx/nginx.conf:ro
volumes_from:
- app
Environment: Docker in Ubuntu running within a WSL layer (which should be invisible to Docker).
Edit: Just to note, I have the sample nginx.conf file provided sitting in the same directory beside docker-compose.yml
