You are using apache or ngnix as your web server ?
You installed your server yourself or by using an image already built in ?
I have installed my server by myself using this instruction and have moved the data by solution 2 of this instruction.
So you are using nginx and your conf file is named default in /etc/nginx/sites-enabled
This is the content of the file you have mentioned:
upstream php-handler {
#server 127.0.0.1:9000;
server unix:/var/run/php/php7.0-fpm.sock;
server {
listen 80;
listen [::]:80;
server_name vatocloud.firewall-gateway.com;
# enforce https
return 301 https://$server_name$request_uri;
#root /var/www/html/;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/live/vatocloud.firewall-gateway.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/vatocloud.firewall-gateway.com/privkey.pem;
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
# could take several months.
add_header X-Robots-Tag none;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.m$
#pagespeed off;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+)\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include fastcgi_params;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~ \.(?:css|js|woff|svg|gif)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# this topic first.
# add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
Go into this folder :
/var/run/php/ do you see a file called : php7.3-fpm.sock ?
If yes modify your default file by remplacing this
By this
unix:/var/run/php/php7.3-fpm.
Restart your server and test again.
If itās not working see the new error in the log file
[quote=āNemskiller, post:25, topic:53065, full:trueā]
unix:/var/run/php/php7.3-fpm.[/quote]
With dot after fpm and without sock after the dot, right?
With .sock
Hmm. Iāve tried to connect my NextCloud but only a blank page appears in the browser window.
2019/05/11 21:31:09 [error] 598#598: *47 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: could not find driver$
Stack trace:
#0 /home/pi/usbdrive/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /home/pi/usbdrive/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /home/pi/usbdrive/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /home/pi/usbdrive/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /home/pi/usbdrive/html/lib/private/DB/Connection.php(151): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /home/pi/usbdrive/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Objec...PHP message: PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect $
Stack trace:
Database connection error.
If your installation is new, you could start from stratch by deleting your config.php file in the config folder of nextcloud.
If your installation isnāt new you have to move this file without removing it to somewhere else. Reload the page and you will see if youāre redirected to the installation page.
Iāll try it. But at the moment, I want to say: Thank you so much! I have learned so much by your patient assistance. Great, that people like you are in the comunity. Thank you!
Oops! Which of them I should (re)move?
pi@raspberrypi:~ $ sudo locate config.php
/home/pi/usbdrive/html/3rdparty/swiftmailer/swiftmailer/lib/swiftmailer_generate_mimes_config.php
/home/pi/usbdrive/html/apps/files_external/lib/config.php
/home/pi/usbdrive/html/config/config.php
/var/www/dataBackup/3rdparty/swiftmailer/swiftmailer/lib/swiftmailer_generate_mimes_config.php
/var/www/dataBackup/apps/files_external/lib/config.php
/var/www/dataBackup/config/config.php
There is a problem
Your nginx conf file says :
Nextcloud web files are in /var/www/html/
But when you search for config.php you find it in your home folder and in a /var/www/databackup folderā¦
Try into /home/pi/usbdrive/html first. I think itās an alias
Not really. I am a bloody beginner. And I think the way Iāve moved my NC from the mSDC onto the external USB drive has complicated everything.
NC doesnāt accept my username/password and doesnāt allow the password to be reset because no email adress be stored.
As I understand the content of config.php, NC connects the wrong database, right?
'instanceid' => '<string>',
'passwordsalt' => '<string>',
'secret' => '<string>',
0 => 'vatocloud.firewall-gateway.com',
'datadirectory' => '/home/pi/usbdrive/html/data',
'dbtype' => 'sqlite3',
'version' => '15.0.7.0',
'overwrite.cli.url' => 'https://vatocloud.firewall-gateway.com',
I think it must be postgresql instead of sqlite3, right?
True
You have to put postresql
The database user
The database name
The database userpassword
Search on the web how to use postgresql, how to connect, how to change userpassword, how to list database names
