Hello all,
I’ve started writing an app to propagate new or changed Contact-cards to some external REST API.
in lib/appinfo/Application.php
I defined a listener which should create a log-entry when triggered by\OCA\DAV\Events\CardUpdateEvent
$dispatcher->addListener(CardUpdatedEvent::class , function($e){
$this->mylog("DAV card updated");
This does not work. However the 2 listeners below, added immediately below the first, do work fine:
$dispatcher->addListener(CardCreatedEvent::class, function($card){
$card = $card->getCard();
$cid = $card->getId();
$this->mylog("deck-card $cid created \n");
$dispatcher->addListener(BeforeUserLoggedInEvent::class, function($usr){
$uname = $usr->getUsername();
$this->mylog("user $uname logged in \n");
Does anyone have a clue what could be the problem? The dev-manual says the DAV CardUpdateEvent should be available in v20. My Nextcloud version is 21.0.2.
Greetings, Michiel
