i’m trying to set up etherpad-lite and ethercalc and access them in nc w ownpad.
i have both pad and calc setup on a separate domain on standard ports, and can access them directly. but when i try to access them thru nc, the instance doesn’t load in the window, instead the area is greyed out with a soft grey/white grid and a small link to the pad appears in the top left corner. it also appears in the name section on mouse over. if i click it, it happily redirects me to the working pad.
in the own pad settings the URLs are like https://sub.domain.com:8000. ie the port is specified manually.
a strange thing about the calc instance is that if i run nc in tor browser it works, but not in vanilla ff. i tried allowing 3rd party cookies i ff to no avail.
(and pad doesn’t work in tor at all for me because of cookie errors. which means i can’t just use tor always.)
if anyone has an inkling?
