Hello
I am installing Nextcloud on Opensuse and I am running into some issues using occ with runuser. The âsudo -u wwwrunâ will not work as you will be prompted for a password. After doing some googling is seem like this is a security feature on Opensuse and the recommendation is to use runuser.
Below it what I have been trying:
sudo runuser -l wwwrun -c âphp /srv/www/nextcloud/occ config:system:set memcache.local --value=\OC\Memcache\APCuâ
This issue I am having is that the â\â in â\OC\Memcache\APCuâ are being ignored and the result is:
âmemcache.localâ => âOCMemcacheAPCuâ
I am guessing the â\â is a special character that needs to be escaped. I thought it would be
sudo runuser -l wwwrun -c âphp /srv/www/nextcloud/occ config:system:set memcache.local --value=\\OC\\Memcache\\APCuâ
however this just led to:
âmemcache.localâ => â\\OC\\Memcache\\APCuâ
Any suggestions?
