I have been facing difficulties in bringing a docker compose project for a NC instance. First, here’s my docker-compose.yaml
version: '3.8'
services:
adminer:
image: adminer:4.8.1-standalone
restart: always
volumes:
- adminer:/var/www/html
environment:
- ADMINER_DESIGN=dracula
networks:
- nextcloud-storage
ports:
- 8080:8080
db:
image: postgres:14.1-alpine
restart: unless-stopped
volumes:
- db:/var/lib/postgresql/data
env_file:
- ./db.env
- ./db.secret.env
networks:
- nextcloud-storage
redis:
image: redis:6.2.6-alpine
command: redis-server --save 60 1 --loglevel warning
volumes:
- redis:/data
networks:
- nextcloud-storage
app:
image: nextcloud:23.0.0-fpm-alpine
volumes:
- nextcloud:/var/www/html
env_file:
- ./nextcloud.env
- ./nextcloud.secret.env
- ./db.env
- ./db.secret.env
depends_on:
- db
- redis
networks:
- nextcloud-storage
- nextcloud-gateway
# The entrypoint executes the command to initialise the cron from cron.php which performs some housekeeping tasks.
# See https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/background_jobs_configuration.html
cron:
volumes:
entrypoint: /cron.sh
depends_on:
- db
- redis
web:
image: caddy:2.4.6-alpine
volumes:
- nextcloud:/var/www/html:ro
- caddy_data:/data
- ./Caddyfile:/etc/caddy/Caddyfile
depends_on:
- app
networks:
- nextcloud-gateway
- ngrok-gateway
volumes:
adminer:
driver_opts:
o: bind
device: ${ADMINER_VOLUME}
type: none
db:
driver_opts:
o: bind
device: ${DB_VOLUME}
type: none
redis:
driver_opts:
o: bind
device: ${REDIS_VOLUME}
type: none
nextcloud:
driver_opts:
o: bind
device: ${APP_VOLUME}
type: none
caddy_data:
driver_opts:
o: bind
device: ${CADDY_VOLUME}
type: none
networks:
ngrok-gateway:
external: true
nextcloud-storage:
nextcloud-gateway:
The DB initialises ok (I think) but the app doesn’t initialise.
it starts with the following log outputs:
Configuring Redis as session handler
Initializing nextcloud 23.0.0.10 ...
Initializing finished
New nextcloud instance
Installing with PostgreSQL database
starting nextcloud installation
An exception occurred while executing a query: SQLSTATE[42P01]: Undefined table: 7 ERROR: relation "oc_users" does not exist
LINE 1: SELECT "uid", "displayname" FROM "oc_users" WHERE "uid_lower...
retrying install...
Error while trying to initialise the database: An exception occurred while executing a query: SQLSTATE[42P01]: Undefined table: 7 ERROR: relation "oc_appconfig" does not exist
LINE 1: SELECT * FROM "oc_appconfig"
Trace: #0 /var/www/html/3rdparty/doctrine/dbal/src/Connection.php(1780): Doctrine\DBAL\Driver\API\PostgreSQL\ExceptionConverter->convert(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
At the same time I see loads of users getting created in the DB and they will be of the form oc_sayak
, oc_sayak1
, oc_sayak2
and so on. sayak
is the value of the env var NEXTCLOUD_ADMIN_USER
. I have tried with setting the POSTGRES_DB
env in the db service and also tried not setting it. I have tried using postgres
, nextcloud
and sayak
as POSTGRES_USER
. But I get the same error each time. The environment variables are available inside the container so that shouldn’t be an issue. I am at my wits end. Any help will be appreciated.
Here is a sample env file:
db.env
POSTGRES_USER=nextcloud
POSTGRES_DB=nextcloud
db.secret.env
POSTGRES_PASSWORD=something
nextcloud.env
POSTGRES_HOST=db
REDIS_HOST=redis
NEXTCLOUD_ADMIN_USER=sayak
NEXTCLOUD_ADMIN_PASSWORD=something
Note: The env vars in the compose volume section are provided using an .env
file.
