Errorinternet_connection_check
    • 30.0.4
    • Rocky Linux 9.5
    • replace me
    • 8.2.27
    • Yes
    • today
    • tarball
ConnectException cURL error 28: Operation timed out after 30001 milliseconds with 0 out of 0 bytes received (see libcurl - Error Codes) for https://nextcloud.com/
Cannot connect to: www.nextcloud.com
6 jan 2025 17:26:54
  1. NO idea
See above.
PASTE HERE
{"reqId":"Z3wEneKAHwwZ63HOUyP1RgAAwxM","level":3,"time":"2025-01-06T16:28:43+00:00","remoteAddr":"2a02:a465:54ef:1:ecfd:e93a:7436:a7d3","user":"robkalmeijer","app":"internet_connection_check","method":"GET","url":"/index.php/settings/ajax/checksetup","message":"Cannot connect to: www.nextcloud.com","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0","version":"30.0.4.1","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 28: Operation timed out after 30001 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for http://www.nextcloud.com/","Code":0,"Trace":[{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":142,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/private/Http/Client/DnsPinMiddleware.php","line":149,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":66,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Client.php","line":333,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Client.php","line":169,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/private/Http/Client/Client.php","line":205,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/apps/settings/lib/SetupChecks/InternetConnectivity.php","line":65,"function":"get","class":"OC\\Http\\Client\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/apps/settings/lib/SetupChecks/InternetConnectivity.php","line":48,"function":"isSiteReachable","class":"OCA\\Settings\\SetupChecks\\InternetConnectivity","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/private/SetupCheck/SetupCheckManager.php","line":34,"function":"run","class":"OCA\\Settings\\SetupChecks\\InternetConnectivity","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/apps/settings/lib/Controller/CheckSetupController.php","line":147,"function":"runAll","class":"OC\\SetupCheck\\SetupCheckManager","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/private/AppFramework/Http/Dispatcher.php","line":208,"function":"check","class":"OCA\\Settings\\Controller\\CheckSetupController","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/private/AppFramework/Http/Dispatcher.php","line":114,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/private/AppFramework/App.php","line":161,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/lib/base.php","line":1003,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/index.php","line":24,"function":"handleRequest","class":"OC","type":"::"}],"File":"/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":210,"message":"Cannot connect to: www.nextcloud.com","exception":{},"CustomMessage":"Cannot connect to: www.nextcloud.com"}}
### Configuration
#### Nextcloud
The output of `occ config:list system` or similar is best, but, if not possible, the contents of your `config.php` file from `/path/to/nextcloud` is fine (make sure to remove any identifiable information!):
PASTE HERE
“system”: {
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“localhost”,
“cloud.robkalmeijer.nl”,
“192.168.1.15”,
“[2a02:a465:54ef:1::1:5]”
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “30.0.4.1”,
“overwrite.cli.url”: “https://cloud.robkalmeijer.nl”,
“overwritehost”: “cloud.robkalmeijer.nl”,
“overwriteprotocol”: “https”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“default_timezone”: “Europe/Amsterdam”,
“installed”: true,
“instanceid”: “REMOVED SENSITIVE VALUE”,
“theme”: “”,
“skeletondirectory”: “/srv/www/vhosts/cloud.robkalmeijer.nl/httpsdocs/core/skeleton”,
“logfile”: “/var/log/nextcloud.log”,
“loglevel”: 2,
“logfilemode”: 416,
“log_rotate_size”: 0,
“logo_url”: “https://cloud.robkalmeijer.nl/”,
“maintenance”: false,
“mail_from_address”: “REMOVED SENSITIVE VALUE”,
“mail_smtpmode”: “smtp”,
“mail_sendmailmode”: “smtp”,
“mail_domain”: “REMOVED SENSITIVE VALUE”,
“mail_smtphost”: “REMOVED SENSITIVE VALUE”,
“mail_smtpport”: “465”,
“mail_send_plaintext_only”: false,
“default_phone_region”: “NL”,
“maintenance_window_start”: 1,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “REMOVED SENSITIVE VALUE”,
“port”: 0,
“timeout”: 0
“redis_log_file”: “/var/log/redis/redis_nextcloud.log”,
“mail_smtpauth”: 1,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“mail_smtpsecure”: “ssl”
"apps": {
    "activity": {
        "enabled": "yes",
        "installed_version": "3.0.0",
        "types": "filesystem"
    "app_api": {
        "enabled": "yes",
        "installed_version": "4.0.3",
        "types": ""
    "backgroundjob": {
        "lastjob": "518"
    "bruteforcesettings": {
        "enabled": "yes",
        "types": ""
    "calendar": {
        "enabled": "yes",
        "installed_version": "5.0.8",
        "types": ""
    "circles": {
        "enabled": "yes",
        "installed_version": "30.0.0",
        "loopback_tmp_scheme": "https",
        "maintenance_run": "0",
        "maintenance_update": "{\"3\":1736180402,\"2\":1736181902,\"1\":1736181902}",
        "migration_22": "1",
        "migration_run": "0",
        "types": "filesystem,dav"
    "cloud_federation_api": {
        "enabled": "yes",
        "installed_version": "1.13.0",
    "comments": {
        "enabled": "yes",
        "installed_version": "1.20.1",
        "types": "logging"
    "contacts": {
        "enabled": "yes",
        "installed_version": "6.1.2",
        "types": "dav"
    "contactsinteraction": {
        "enabled": "yes",
        "installed_version": "1.11.0",
        "types": "dav"
    "core": {
        "backgroundjobs_mode": "cron",
        "emailTestSuccessful": "1",
        "files_metadata_installed": "1",
        "installedat": "1606840276.1472",
        "lastcron": 1736181902,
        "lastupdateResult": "[]",
        "lastupdatedat": 1736180781,
        "mail_providers_enabled": false,
        "metadataGenerationDone": true,
        "moveavatarsdone": "yes",
        "previewsCleanedUp": "1",
        "public_files": "files_sharing\/public.php",
        "public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
        "scss.variables": "9b0e5104e6a3c6a1b450df21a62de115",
        "shareapi_allow_public_upload": "no",
        "shareapi_default_expire_date": "yes",
        "theming.variables": "3380c74585402bc749599a676554ab7b",
        "updater.secret.created": "1687715832",
        "vendor": "nextcloud",
        "files_metadata": {
            "photos-original_date_time": {
                "value": null,
                "type": "int",
                "etag": "",
                "indexed": true,
                "editPermission": 0
            "photos-size": {
                "value": null,
                "type": "array",
                "etag": "",
                "indexed": false,
                "editPermission": 0
            "photos-exif": {
                "value": null,
                "type": "array",
                "etag": "",
                "indexed": false,
                "editPermission": 0
            "photos-ifd0": {
                "value": null,
                "type": "array",
                "etag": "",
                "indexed": false,
                "editPermission": 0
            "blurhash": {
                "value": null,
                "type": "string",
                "etag": "24a002f41a2d89697f2c53f9de5e7a34",
                "indexed": false,
                "editPermission": 0
        "oc.integritycheck.checker": []
    "dashboard": {
        "enabled": "yes",
        "installed_version": "7.10.0",
        "types": ""
    "dav": {
        "buildCalendarReminderIndex": "yes",
        "buildCalendarSearchIndex": "yes",
        "builtSocialSearchIndex": "yes",
        "chunks_migrated": "1",
        "enabled": "yes",
        "installed_version": "1.31.1",
        "regeneratedBirthdayCalendarsForYearFix": "yes",
    "federatedfilesharing": {
        "enabled": "yes",
        "installed_version": "1.20.0",
        "types": ""
    "federation": {
        "enabled": "yes",
        "types": "authentication"
    "files": {
        "cronjob_scan_files": "500",
        "enabled": "yes",
        "installed_version": "2.2.0",
        "mimetype_version": "30.0.1.2",
    "files_accesscontrol": {
        "enabled": "yes",
    "files_downloadlimit": {
        "enabled": "yes",
        "types": ""
    "files_external": {
        "enabled": "yes",
        "installed_version": "1.22.0",
    "files_pdfviewer": {
        "enabled": "yes",
        "types": ""
    "files_reminders": {
        "enabled": "yes",
        "installed_version": "1.3.0",
        "types": ""
    "files_rightclick": {
        "enabled": "no",
        "installed_version": "1.6.0",
        "types": ""
    "files_sharing": {
        "enabled": "yes",
    "files_texteditor": {
        "enabled": "no",
        "installed_version": "2.8.0",
        "types": ""
    "files_trashbin": {
        "enabled": "yes",
    "files_versions": {
        "enabled": "yes",
        "installed_version": "1.23.0",
    "firstrunwizard": {
        "enabled": "yes",
        "types": "logging"
    "gallery": {
        "enabled": "no",
        "installed_version": "18.3.0",
        "types": ""
    "groupfolders": {
        "enabled": "yes",
        "installed_version": "18.0.8",
    "logreader": {
        "enabled": "yes",
        "relativedates": "1",
        "types": "logging"
    "lookup_server_connector": {
        "enabled": "yes",
        "installed_version": "1.18.0",
    "nextcloud_announcements": {
        "enabled": "yes",
        "installed_version": "2.0.0",
        "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
        "types": "logging"
    "notifications": {
        "enabled": "yes",
        "types": "logging"
    "oauth2": {
        "enabled": "yes",
        "installed_version": "1.18.1",
    "ownershiptransfer": {
        "enabled": "yes",
        "installed_version": "1.0.1",
        "types": ""
    "password_policy": {
        "enabled": "yes",
        "enforceNumericCharacters": "1",
        "enforceUpperLowerCase": "1",
    "photos": {
        "enabled": "yes",
        "installed_version": "3.0.2",
        "lastPlaceMappedUser": "robkalmeijer",
        "lastPlaceMappingDone": "true",
        "types": "dav,authentication"
    "privacy": {
        "enabled": "yes",
        "readableLocation": "nl",
        "types": ""
    "provisioning_api": {
        "enabled": "yes",
        "types": "prevent_group_restriction"
    "recommendations": {
        "enabled": "yes",
        "types": ""
    "related_resources": {
        "enabled": "yes",
        "installed_version": "1.5.0",
        "types": ""
    "serverinfo": {
        "cached_count_filecache": "2309",
        "cached_count_storages": "3",
        "enabled": "yes",
        "types": ""
    "settings": {
        "enabled": "yes",
        "types": ""
    "sharebymail": {
        "enabled": "yes",
    "support": {
        "SwitchUpdaterServerHasRun": "yes",
        "enabled": "yes",
        "types": "session"
    "survey_client": {
        "database": "no",
        "enabled": "yes",
        "last_report": "{\"id\":\"ocgojvvzr5v7\",\"items\":[[\"server\",\"version\",\"15.0.7.0\"],[\"server\",\"code\",\"other\"],[\"server\",\"enable_avatars\",\"yes\"],[\"server\",\"enable_previews\",\"yes\"],[\"server\",\"memcache.local\",\"none\"],[\"server\",\"memcache.distributed\",\"none\"],[\"server\",\"asset-pipeline.enabled\",\"no\"],[\"server\",\"filelocking.enabled\",\"yes\"],[\"server\",\"memcache.locking\",\"none\"],[\"server\",\"debug\",\"no\"],[\"server\",\"cron\",\"ajax\"],[\"php\",\"version\",\"7.3.6\"],[\"php\",\"memory_limit\",536870912],[\"php\",\"max_execution_time\",3600],[\"php\",\"upload_max_filesize\",535822336],[\"database\",\"type\",\"mysql\"],[\"database\",\"version\",\"10.3.15\"],[\"database\",\"size\",1286144],[\"apps\",\"accessibility\",\"1.1.0\"],[\"apps\",\"activity\",\"2.8.2\"],[\"apps\",\"calendar\",\"1.6.5\"],[\"apps\",\"cloud_federation_api\",\"0.1.0\"],[\"apps\",\"comments\",\"1.5.0\"],[\"apps\",\"contacts\",\"3.1.1\"],[\"apps\",\"dav\",\"1.8.1\"],[\"apps\",\"federatedfilesharing\",\"1.5.0\"],[\"apps\",\"federation\",\"1.5.0\"],[\"apps\",\"files\",\"1.10.0\"],[\"apps\",\"files_pdfviewer\",\"1.4.0\"],[\"apps\",\"files_sharing\",\"1.7.0\"],[\"apps\",\"files_texteditor\",\"2.7.0\"],[\"apps\",\"files_trashbin\",\"1.5.0\"],[\"apps\",\"files_versions\",\"1.8.0\"],[\"apps\",\"files_videoplayer\",\"1.4.0\"],[\"apps\",\"firstrunwizard\",\"2.4.0\"],[\"apps\",\"gallery\",\"18.2.0\"],[\"apps\",\"logreader\",\"2.0.0\"],[\"apps\",\"lookup_server_connector\",\"1.3.0\"],[\"apps\",\"nextcloud_announcements\",\"1.4.0\"],[\"apps\",\"notifications\",\"2.3.0\"],[\"apps\",\"oauth2\",\"1.3.0\"],[\"apps\",\"password_policy\",\"1.5.0\"],[\"apps\",\"provisioning_api\",\"1.5.0\"],[\"apps\",\"serverinfo\",\"1.5.0\"],[\"apps\",\"sharebymail\",\"1.5.0\"],[\"apps\",\"support\",\"1.0.0\"],[\"apps\",\"survey_client\",\"1.3.0\"],[\"apps\",\"systemtags\",\"1.5.0\"],[\"apps\",\"theming\",\"1.6.0\"],[\"apps\",\"twofactor_backupcodes\",\"1.4.1\"],[\"apps\",\"updatenotification\",\"1.5.0\"],[\"apps\",\"workflowengine\",\"1.5.0\"],[\"stats\",\"num_files\",219],[\"stats\",\"num_users\",1],[\"stats\",\"num_storages\",2],[\"stats\",\"num_storages_local\",1],[\"stats\",\"num_storages_home\",1],[\"stats\",\"num_storages_other\",0],[\"stats\",\"num_comments\",0],[\"stats\",\"num_comment_markers\",0],[\"stats\",\"num_systemtags\",0],[\"stats\",\"num_systemtags_mappings\",0],[\"files_sharing\",\"num_shares\",0],[\"files_sharing\",\"num_shares_user\",0],[\"files_sharing\",\"num_shares_groups\",0],[\"files_sharing\",\"num_shares_link\",0],[\"files_sharing\",\"num_shares_link_no_password\",0],[\"files_sharing\",\"num_fed_shares_sent\",0],[\"files_sharing\",\"num_fed_shares_received\",0],[\"encryption\",\"enabled\",\"no\"],[\"encryption\",\"default_module\",\"no\"]]}",
        "last_sent": "1560734229",
        "types": ""
    "systemtags": {
        "enabled": "yes",
        "types": "logging"
    "text": {
        "enabled": "yes",
        "installed_version": "4.1.0",
        "types": "dav"
    "theming": {
        "backgroundMime": "backgroundColor",
        "cachebuster": "4",
        "enabled": "yes",
        "installed_version": "2.5.0",
        "logoDimensions": "512x512",
        "logoMime": "image\/jpeg",
        "name": "Rob's cloud",
        "slogan": "***REMOVED SENSITIVE VALUE***",
        "types": "logging"
    "twofactor_backupcodes": {
        "enabled": "yes",
        "installed_version": "1.19.0",
        "types": ""
    "updatenotification": {
        "calendar": "5.0.7",
        "contacts": "6.1.1",
        "core": "30.0.2.2",
        "enabled": "yes",
        "files_accesscontrol": "1.18.1",
        "files_rightclick": "0.15.1",
        "groupfolders": "18.0.8",
        "types": "",
        "update_check_errors": 0
    "user_status": {
        "enabled": "yes",
        "installed_version": "1.10.0",
        "types": ""
    "viewer": {
        "enabled": "yes",
        "types": ""
    "weather_status": {
        "enabled": "no",
        "types": ""
    "webhook_listeners": {
        "enabled": "yes",
        "installed_version": "1.1.0-dev",
    "whiteboard": {
        "enabled": "yes",
        "installed_version": "1.0.4",
        "types": ""
    "workflowengine": {
        "enabled": "yes",
        "installed_version": "2.12.0",
Hi RK,
I can see your current install on the Internet - is this a domain check process issue now resolved or are you still having issues and for which app(s)?
I don’t know what is doing the test.
Last entry 6 jan 2025 17:28:43
