example
longer
example
here
Nextcloud version (eg, 20.0.5): 20.0.7
Operating system and version (eg, Ubuntu 20.04): Unraid, docker linuxserver/nextcloud
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
The issue you are facing: The connector to onlyoffice isn’t working due to the error above. This happened after an upgrade to Nextcloud 20. As part of fault finding this, I have set up (and migrated some data) to a separate instance of nextcloud (which I will refer to as instance 2), so I now have everything duplicated and while not exactly dev/test/prod, it does serve as a useful fault finding tool.
For example, if I point my instance 1 at the working only office connector from instance 2 I get the same error. This would seem to rule out anything outside of nextcloud from being the issue.
Edit: This is now happening on a second instance, only thing I can think of is that the permissions may have been changed, if that were the case, which files do you think I would need to check around the connection to OnlyOffice?
- Add correct URL to Document Editing Service Address
Note: This log is truncated due to size, I could supply the whole thing as an attachment if necessary
'datadirectory' => '/data',
'instanceid' => 'octyuph8h24o',
'passwordsalt' => 'removed',
'secret' => 'removed',
0 => 'nextcloud.domain.co.nz',
'version' => '20.0.7.1',
'overwrite.cli.url' => 'https://nextcloud.domain.co.nz',
'dbname' => 'nextcloud',
'dbhost' => '192.168.43.11:3306',
'dbuser' => 'nextcloud',
'dbpassword' => 'removed',
'ldapIgnoreNamingRules' => false,
'theme' => '',
'loglevel' => 2,
'mail_from_address' => 'chatterbox',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'removed',
'mail_smtphost' => 'removed',
'mail_smtpauth' => 1,
'mail_smtpname' => 'removed',
'mail_smtppassword' => 'removed',
'mail_smtpport' => '587',
'onlyoffice' =>
'verify_peer_off' => true,
'mail_smtpsecure' => 'tls',
'updater.secret' => 'updater secret withheld',
(Truncated)
172.18.0.2 - quentinj [07/Feb/2021:11:15:13 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications?format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:15:40 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:15:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:15:41 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:15:41 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:16:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:16:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:16:10 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:16:13 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:16:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:16:42 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:16:42 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:16:43 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:17:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:17:11 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:17:14 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:17:14 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:17:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:17:41 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:17:46 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:17:46 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:18:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:18:11 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:18:18 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:18:18 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:18:41 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:18:42 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:18:52 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:18:52 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:19:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:19:11 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:19:22 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:19:22 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:19:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:19:41 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:19:54 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:19:54 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:20:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:20:11 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - - [07/Feb/2021:11:20:11 +1300] "PUT /apps/user_status/heartbeat HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - - [07/Feb/2021:11:20:11 +1300] "GET /ocs/v2.php/apps/user_status/api/v1/user_status HTTP/1.1" 200 177 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:20:13 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications?format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:20:26 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:20:26 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:20:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:20:41 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:20:58 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:20:58 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:21:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:21:11 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:21:30 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:21:30 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:21:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:21:43 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:22:02 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:22:02 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:22:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:22:13 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:22:34 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:22:34 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:22:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:22:41 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:23:06 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:23:06 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:23:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:23:17 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:23:38 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:23:38 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:23:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:23:47 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:24:12 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:24:12 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:24:12 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:24:17 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:24:40 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:24:42 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:24:42 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:24:47 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:25:10 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:25:11 +1300] "PUT /apps/user_status/heartbeat HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - - [07/Feb/2021:11:25:11 +1300] "GET /ocs/v2.php/apps/user_status/api/v1/user_status HTTP/1.1" 200 177 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:25:13 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications?format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:25:14 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:25:14 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:25:17 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
172.18.0.2 - quentinj [07/Feb/2021:11:25:41 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 286 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:25:47 +1300] "GET /ocs/v2.php/core/navigation/apps?absolute=true&format=json HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - quentinj [07/Feb/2021:11:25:47 +1300] "PROPFIND /remote.php/dav/files/8616ba34-59cd-1039-9aad-d18f70623e38/ HTTP/1.1" 207 284 "-" "Mozilla/5.0 (Macintosh) mirall/3.0.3git (build 3799) (Nextcloud)"
172.18.0.2 - - [07/Feb/2021:11:25:49 +1300] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 0 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1 Safari/605.1.15"
