I have updated, after a few months, my server for NextCloud and, with the 4.1.1 version of richdocuments, I get the following errors:
Error: simplexml_load_string(): Entity: line 1: parser error : Start tag expected, '<' not found at /var/www/nextcloud/apps/richdocuments/lib/WOPI/Parser.php#47
Error: simplexml_load_string(): Permissions-Policy: interest-cohort=() at /var/www/nextcloud/apps/richdocuments/lib/WOPI/Parser.php#47
Error: simplexml_load_string(): ^ at /var/www/nextcloud/apps/richdocuments/lib/WOPI/Parser.php#47
for all three the description is as follows:
<<closure>>
OC\Log\ErrorHandler::onError()
/var/www/nextcloud/apps/richdocuments/lib/WOPI/Parser.php - line 47:
/var/www/nextcloud/apps/richdocuments/lib/Controller/SettingsController.php - line 175:
OCA\Richdocuments\WOPI\Parser->getUrlSrc()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 218:
OCA\Richdocuments\Controller\SettingsController->setSettings()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 127:
/var/www/nextcloud/lib/private/AppFramework/App.php - line 157:
/var/www/nextcloud/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main()
/var/www/nextcloud/lib/base.php - line 993:
OC\Route\Router->match()
/var/www/nextcloud/index.php - line 37:
OC::handleRequest()
and then again:
Exception: Call to a member function xpath() on bool
OC::handleRequest()
Generato daError: Call to a member function xpath() on bool
OC::handleRequest()
The consequence is that, while everything else works, Collabora Online is no longer reachable.
The link https://my-site/loleaflet/dist/admin/admin.html displays the empty dashboard with the writing:
Server has been shut down; please reload the page.
In NextCloud, on the page https://my-site/settings/admin/richdocuments, the message appears:
Could not establish connection to the Collabora Online server
The configurations are the same as when the site was working.
Server details
Operating system:
Ubuntu 20.04.2
Web server:
Nginx 1.21.0
Database:
MariaDB 10.5.10
PHP version:
8.0.7
Nextcloud version:
21.0.2
Version of the richdocuments app
Collabora Online 4.1.1
collabora/code:latest
DockerVersion
19.03.11
curl -k https://localhost:9980
OK
