If you’re urgently looking for support to keep your business running, consider checking out our paid support options.
example
longer
example
here
Remember, the below information may be requested if it isn’t supplied; for fastest response please provide as much as you can
Please delete everything above when creating your topic, just provide the following:
Nextcloud version (eg, 12.0.2): 11
Operating system and version (eg, Ubuntu 17.04): macOS 10.11.6
PHP version (eg, 7.1): 7.0
The issue you are facing: Upgrade (? → 11) is stuck on step “Starting code integrity check”.
- I started the upgrade via the web interface, it faced me whether to keep the maintenance mode enabled or not → the upgrade was successful, but not completed…
- switched to the command line with
sudo -u _www php occ upgrade
- Retried step 2 multiple times, tried things in between, I’m stuck on this screen:
pls tell me where to find in the file system
'instanceid' => 'ozz4m',
'passwordsalt' => 'NpJzzzz+C',
'secret' => 'q40PTYuRzzzzzzfQnZ1',
0 => 'clzzzd.de',
'datadirectory' => '/Vzzzzalfeld.de/data',
'overwrite.cli.url' => 'https://clzzzzld.de',
'dbtype' => 'sqlite3',
'version' => '9.1.6.1',
'logtimezone' => 'UTC',
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'mail_from_address' => 'sjzzzud',
'mail_smtpmode' => 'php',
'mail_domain' => 'szzzzzzeld.de',
'maintenance' => true,
'loglevel' => 0,
'updater.secret' => '$2y$1zzzzzbbsuCoiKOJ/ohp.',
[Wed Jan 03 16:46:22.381584 2018] [authz_core:error] [pid 10659] [client 841.206:51875] AH01630: client denied by server configuration: /Volumes/My Book Thunderbolt Duo/Library/Server/Web/Data/Sites/Default/
[Wed Jan 03 16:48:22.610259 2018] [authz_core:error] [pid 10698] [client 806:51896] AH01630: client denied by server configuration: /Volumes/My Book Thunderbolt Duo/Library/Server/Web/Data/Sites/Default/
I guess, thats the wrong log location…
