Hi !
i’m french, sorry for my english
I have a mistake when sending a comment: “Error occurred while posting comment”
my log :
nextcloud.log :
{"reqId":"IpHEvhD8M85YZYGlG9JQ","level":4,"time":"2017-09-15T15:25:33+02:00","remoteAddr":"192.168.42.131","user":"67830","app":"webdav","method":"POST","url":"\/remote.php\/dav\/comments\/files\/214\/","message":"Exception: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Message\":\"Invalid input values\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Comments\\\/CommentsPlugin.php(120): OCA\\\\DAV\\\\Comments\\\\CommentsPlugin->createComment('files', '214', Array, 'application\\\/jso...')\\n#1 [internal function]: OCA\\\\DAV\\\\Comments\\\\CommentsPlugin->httpPost(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#2 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:POST', Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(253): Sabre\\\\DAV\\\\Server->exec()\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(33): OCA\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(162): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Comments\\\/CommentsPlugin.php\",\"Line\":247}","userAgent":"Mozilla\/5.0 (Windows NT 6.1; WOW64; rv:42.0) Gecko\/20100101 Firefox\/42.0","version":"12.0.2.0"}
my version : nextcloud 12.0.2.0
apache : Apache/2.4.10
php : PHP 7.0.23
database : MySQL
my config :
'instanceid' => 'ocq1mtltl2by',
'passwordsalt' => '********',
'secret' => '********',
0 => 'test.sdis.fr',
1 => 'www.test.sdis.fr',
2 => '192.168.x.x',
'datadirectory' => '/var/ownclouddata',
'overwrite.cli.url' => 'https://test.sdis.fr',
'version' => '12.0.2.0',
'dbname' => 'ocdb',
'dbhost' => 'localhost',
'dbuser' => 'ocuser',
'dbpassword' => '********',
'default_language' => 'fr',
'defaultapp' => 'files',
'knowledgebaseenabled' => false,
'enable_previews' => true,
'logfile' => '/var/log/nextcloud.log',
'loglevel' => 2,
'logtimezone' => 'Europe/Paris',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'timeout' => 0,
'dbindex' => 0,
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'test',
'mail_domain' => 'sdis.fr',
'mail_smtphost' => 'testmail.sdis.fr',
'mail_smtpport' => '25',
'ldapIgnoreNamingRules' => false,
'theme' => 'sdis',
'appstore.experimental.enabled' => true,
'check_for_working_htaccess' => true,
'updater.server.url' => 'https://updates.nextcloud.com/updater_server/',
'updatechecker' => false,
'check_for_working_webdav' => true,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'trusted_proxies' => array('172.17.x.x', '172.17.x.x'),
'forwarded_for_headers' => array('HTTP_X_FORWARDED_FOR'),
app list :
sudo -u www-data ./occ app:list
- activity: 2.5.2
- bruteforcesettings: 1.0.2
- comments: 1.2.0
- dav: 1.3.0
- federatedfilesharing: 1.2.0
- federation: 1.2.0
- files: 1.7.2
- files_clipboard: 0.6.4
- files_pdfviewer: 1.1.1
- files_sharing: 1.4.0
- files_texteditor: 2.4.1
- files_trashbin: 1.2.0
- files_versions: 1.5.0
- files_videoplayer: 1.1.0
- gallery: 17.0.0
- impersonate: 1.0.1
- logreader: 2.0.0
- lookup_server_connector: 1.0.0
- nextcloud_announcements: 1.1
- notifications: 2.0.0
- oauth2: 1.0.5
- password_policy: 1.2.2
- provisioning_api: 1.2.0
- richdocuments: 1.12.34
- serverinfo: 1.2.0
- sharebymail: 1.2.0
- socialsharing_email: 1.0.1
- survey_client: 1.0.0
- systemtags: 1.2.0
- theming: 1.3.0
- twofactor_backupcodes: 1.1.1
- updatenotification: 1.2.0
- user_ldap: 1.2.1
- workflowengine: 1.2.0
Disabled: - admin_audit
- encryption
- files_external
- firstrunwizard
- user_external
Thank you for your help
Laurent
