Ich bin schon froh dass ich es zustande gebracht hab das System auf SD-Karte zum laufen zu bekommen.
Sofern es mir nicht eklatante Vorteile bringt von der SSD zu booten werd ich das so beibehalten und eine zweite SD-Karte als Backup anlegen.
hier noch die ausgabe von sudo dmesg
matthias@nextcloudpi:~ $ sudo dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 6.6.31+rpt-rpi-v8 (serge@raspberrypi.com) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29)
[ 0.000000] KASLR enabled
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000dc00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000000dc00000..0x000000002dbfffff (524288 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x000000003ef646a0..0x000000003ef64a9f (1 KiB) nomap non-reusable nvram@1
[ 0.000000] OF: reserved mem: 0x000000003ef64ae0..0x000000003ef64b15 (0 KiB) nomap non-reusable nvram@0
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 30 pages/cpu s85672 r8192 d29016 u122880
[ 0.000000] pcpu-alloc: s85672 r8192 d29016 u122880 alloc=30*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:D4:A2:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=8ded0318-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 996912
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 3336228K/4050944K available (13376K kernel code, 2210K rwdata, 4264K rodata, 4864K init, 1083K bss, 190428K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 43180 entries in 169 pages
[ 0.000000] ftrace: allocated 169 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000332] Console: colour dummy device 80x25
[ 0.000348] printk: console [tty1] enabled
[ 0.000445] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000464] pid_max: default: 32768 minimum: 301
[ 0.000538] LSM: initializing lsm=capability,integrity
[ 0.000746] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000807] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001699] cgroup: Disabling memory control group subsystem
[ 0.003276] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.003380] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.003496] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.003751] rcu: Hierarchical SRCU implementation.
[ 0.003760] rcu: Max phase no-delay instances is 1000.
[ 0.005671] EFI services will not be available.
[ 0.005987] smp: Bringing up secondary CPUs ...
[ 0.006590] Detected PIPT I-cache on CPU1
[ 0.006715] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.007383] Detected PIPT I-cache on CPU2
[ 0.007473] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.008159] Detected PIPT I-cache on CPU3
[ 0.008252] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.008345] smp: Brought up 1 node, 4 CPUs
[ 0.008362] SMP: Total of 4 processors activated.
[ 0.008371] CPU features: detected: 32-bit EL0 Support
[ 0.008377] CPU features: detected: 32-bit EL1 Support
[ 0.008386] CPU features: detected: CRC32 instructions
[ 0.008490] CPU: All CPU(s) started at EL2
[ 0.008507] alternatives: applying system-wide alternatives
[ 0.010859] devtmpfs: initialized
[ 0.020773] Enabled cp15_barrier support
[ 0.020805] Enabled setend support
[ 0.020972] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.020997] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033439] pinctrl core: initialized pinctrl subsystem
[ 0.033977] DMI not present or invalid.
[ 0.034473] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.036358] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.036615] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.037039] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.037105] audit: initializing netlink subsys (disabled)
[ 0.037281] audit: type=2000 audit(0.036:1): state=initialized audit_enabled=0 res=1
[ 0.037790] thermal_sys: Registered thermal governor 'step_wise'
[ 0.037842] cpuidle: using governor menu
[ 0.038069] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.038185] ASID allocator initialised with 32768 entries
[ 0.039130] Serial: AMBA PL011 UART driver
[ 0.045975] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.056226] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-05-24T15:30:04, variant start
[ 0.060223] raspberrypi-firmware soc:firmware: Firmware hash is 4942b7633c0ff1af1ee95a51a33b56a9dae47529
[ 0.070521] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[ 0.070536] Modules: 0 pages in range for non-PLT usage
[ 0.070542] Modules: 517792 pages in range for PLT usage
[ 0.077092] bcm2835-dma fe007000.dma-controller: DMA legacy API manager, dmachans=0x1
[ 0.078974] iommu: Default domain type: Translated
[ 0.078985] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.080518] SCSI subsystem initialized
[ 0.080695] usbcore: registered new interface driver usbfs
[ 0.080736] usbcore: registered new interface driver hub
[ 0.080780] usbcore: registered new device driver usb
[ 0.081145] pps_core: LinuxPPS API ver. 1 registered
[ 0.081154] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.081172] PTP clock support registered
[ 0.082244] vgaarb: loaded
[ 0.082692] clocksource: Switched to clocksource arch_sys_counter
[ 0.083129] VFS: Disk quotas dquot_6.6.0
[ 0.083170] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.083277] FS-Cache: Loaded
[ 0.084433] CacheFiles: Loaded
[ 0.092482] NET: Registered PF_INET protocol family
[ 0.092997] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.097489] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.097543] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.097562] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.097827] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.098852] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.099289] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.099485] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.099550] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.099773] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.102966] RPC: Registered named UNIX socket transport module.
[ 0.102978] RPC: Registered udp transport module.
[ 0.102983] RPC: Registered tcp transport module.
[ 0.102989] RPC: Registered tcp-with-tls transport module.
[ 0.102995] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.103029] PCI: CLS 0 bytes, default 64
[ 0.103259] Trying to unpack rootfs image as initramfs...
[ 0.107220] kvm [1]: IPA Size Limit: 44 bits
[ 0.108450] kvm [1]: vgic interrupt IRQ9
[ 0.108499] kvm [1]: Hyp mode initialized successfully
[ 0.920283] Freeing initrd memory: 17684K
[ 1.128703] Initialise system trusted keyrings
[ 1.128987] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.129077] zbud: loaded
[ 1.129769] NFS: Registering the id_resolver key type
[ 1.129793] Key type id_resolver registered
[ 1.129800] Key type id_legacy registered
[ 1.129825] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.129834] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.130492] Key type asymmetric registered
[ 1.130504] Asymmetric key parser 'x509' registered
[ 1.130555] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.130742] io scheduler mq-deadline registered
[ 1.130753] io scheduler kyber registered
[ 1.130792] io scheduler bfq registered
[ 1.131688] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 23)
[ 1.134193] pinctrl-bcm2835 fe200000.gpio: GPIO_OUT persistence: yes
[ 1.136378] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.136404] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.136445] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.136486] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
[ 1.137494] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.137510] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.137524] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.137572] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.137661] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.141126] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.141265] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.141397] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.141473] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.248772] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.248908] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.249001] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.249289] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.258772] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.258810] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.258827] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.258886] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.258898] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.259126] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.259276] pcieport 0000:00:00.0: PME: Signaling with IRQ 27
[ 1.259615] pcieport 0000:00:00.0: AER: enabled with IRQ 27
[ 1.268997] iproc-rng200 fe104000.rng: hwrng registered
[ 1.269249] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.280237] brd: module loaded
[ 1.286568] loop: module loaded
[ 1.287215] Loading iSCSI transport class v2.0-870.
[ 1.291363] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.494771] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.495857] usbcore: registered new device driver r8152-cfgselector
[ 1.495895] usbcore: registered new interface driver r8152
[ 1.495930] usbcore: registered new interface driver lan78xx
[ 1.495962] usbcore: registered new interface driver smsc95xx
[ 1.543512] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.543544] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.545276] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0300240000000890
[ 1.546019] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.546039] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.546056] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.546267] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 1.546283] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.546293] usb usb1: Product: xHCI Host Controller
[ 1.546302] usb usb1: Manufacturer: Linux 6.6.31+rpt-rpi-v8 xhci-hcd
[ 1.546310] usb usb1: SerialNumber: 0000:01:00.0
[ 1.546904] hub 1-0:1.0: USB hub found
[ 1.546944] hub 1-0:1.0: 1 port detected
[ 1.547469] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 1.547485] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.547495] usb usb2: Product: xHCI Host Controller
[ 1.547504] usb usb2: Manufacturer: Linux 6.6.31+rpt-rpi-v8 xhci-hcd
[ 1.547513] usb usb2: SerialNumber: 0000:01:00.0
[ 1.547960] hub 2-0:1.0: USB hub found
[ 1.548000] hub 2-0:1.0: 4 ports detected
[ 1.548885] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.548994] dwc_otg: FIQ enabled
[ 1.549001] dwc_otg: NAK holdoff enabled
[ 1.549007] dwc_otg: FIQ split-transaction FSM enabled
[ 1.549017] Module dwc_common_port init
[ 1.549681] usbcore: registered new interface driver uas
[ 1.549739] usbcore: registered new interface driver usb-storage
[ 1.550191] mousedev: PS/2 mouse device common for all mice
[ 1.553691] sdhci: Secure Digital Host Controller Interface driver
[ 1.553706] sdhci: Copyright(c) Pierre Ossman
[ 1.553928] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.556689] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.556971] hid: raw HID events driver (C) Jiri Kosina
[ 1.557104] usbcore: registered new interface driver usbhid
[ 1.557114] usbhid: USB HID core driver
[ 1.562409] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.563786] NET: Registered PF_PACKET protocol family
[ 1.563878] Key type dns_resolver registered
[ 1.590124] registered taskstats version 1
[ 1.590350] Loading compiled-in X.509 certificates
[ 1.601502] Key type .fscrypt registered
[ 1.601524] Key type fscrypt-provisioning registered
[ 1.608814] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.609255] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.609603] fe201000.serial: ttyAMA1 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.609848] serial serial0: tty port ttyAMA1 registered
[ 1.612904] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.613150] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.614059] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.614075] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.641107] of_cfs_init
[ 1.641210] of_cfs_init: OK
[ 1.641423] clk: Disabling unused clocks
[ 1.679264] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.688825] Freeing unused kernel memory: 4864K
[ 1.689064] Run /init as init process
[ 1.689072] with arguments:
[ 1.689077] /init
[ 1.689082] splash
[ 1.689088] with environment:
[ 1.689093] HOME=/
[ 1.689098] TERM=linux
[ 1.729141] mmc1: new high speed SDIO card at address 0001
[ 1.784322] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 1.785230] mmcblk0: mmc0:aaaa SD128 119 GiB
[ 1.787998] mmcblk0: p1 p2
[ 1.788501] mmcblk0: mmc0:aaaa SD128 119 GiB (quirks 0x00004000)
[ 1.802981] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.953504] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.953539] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.953552] usb 1-1: Product: USB2.0 Hub
[ 1.955935] hub 1-1:1.0: USB hub found
[ 1.956254] hub 1-1:1.0: 4 ports detected
[ 2.240965] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 2.245295] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 2.344266] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 2.379849] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 2.381585] Registered IR keymap rc-cec
[ 2.381758] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 2.381948] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 2.386310] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/fef00700.hdmi/sound/card0/input1
[ 2.388873] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 2.393567] Registered IR keymap rc-cec
[ 2.393755] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 2.393941] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input2
[ 2.399350] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/fef05700.hdmi/sound/card1/input3
[ 2.399950] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 2.400431] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 2.402436] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.402985] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.403347] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.403576] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.403985] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 2.407122] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 2.407530] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 2.415769] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 2.415945] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 2.554708] raid6: neonx8 gen() 1813 MB/s
[ 2.622746] raid6: neonx4 gen() 1816 MB/s
[ 2.690693] raid6: neonx2 gen() 1446 MB/s
[ 2.758713] raid6: neonx1 gen() 1044 MB/s
[ 2.819332] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.826732] raid6: int64x8 gen() 1013 MB/s
[ 2.846010] usb 2-2: New USB device found, idVendor=0bda, idProduct=9201, bcdDevice=f2.00
[ 2.846028] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.846040] usb 2-2: Product: RTL9201
[ 2.846049] usb 2-2: Manufacturer: Realtek
[ 2.846058] usb 2-2: SerialNumber: 012345678994
[ 2.894715] raid6: int64x4 gen() 1000 MB/s
[ 2.962700] raid6: int64x2 gen() 937 MB/s
[ 3.030708] raid6: int64x1 gen() 728 MB/s
[ 3.030717] raid6: using algorithm neonx4 gen() 1816 MB/s
[ 3.098699] raid6: .... xor() 1372 MB/s, rmw enabled
[ 3.098709] raid6: using neon recovery algorithm
[ 3.101107] xor: measuring software checksum speed
[ 3.104561] 8regs : 2901 MB/sec
[ 3.107759] 32regs : 3100 MB/sec
[ 3.111578] arm64_neon : 2589 MB/sec
[ 3.111588] xor: using function: 32regs (3100 MB/sec)
[ 3.122788] usb 2-2: Enable of device-initiated U1 failed.
[ 3.123681] usb 2-2: Enable of device-initiated U2 failed.
[ 3.152776] usb 2-2: Enable of device-initiated U1 failed.
[ 3.153678] usb 2-2: Enable of device-initiated U2 failed.
[ 3.180616] scsi host0: uas
[ 3.195701] Btrfs loaded, zoned=no, fsverity=no
[ 3.404552] scsi 0:0:0:0: Direct-Access SanDisk SDSSDH3 1T02 1.02 PQ: 0 ANSI: 6
[ 3.436384] sd 0:0:0:0: [sda] 2000409264 512-byte logical blocks: (1.02 TB/954 GiB)
[ 3.438860] sd 0:0:0:0: [sda] Write Protect is off
[ 3.438883] sd 0:0:0:0: [sda] Mode Sense: 37 00 00 08
[ 3.441778] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.443084] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 3.443098] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 3.456320] sda: sda1
[ 3.456756] sd 0:0:0:0: [sda] Attached SCSI disk
[ 3.526995] BTRFS: device label myCloudDrive devid 1 transid 9579 /dev/sda1 scanned by (udev-worker) (143)
[ 3.606215] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
[ 4.195759] systemd[1]: System time before build time, advancing clock.
[ 4.368905] NET: Registered PF_INET6 protocol family
[ 4.370171] Segment Routing with IPv6
[ 4.370205] In-situ OAM (IOAM) with IPv6
[ 4.437122] systemd[1]: systemd 252.26-1~deb12u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 4.437162] systemd[1]: Detected architecture arm64.
[ 4.441965] systemd[1]: Hostname set to <nextcloudpi>.
[ 5.714489] systemd[1]: Queued start job for default target graphical.target.
[ 5.737890] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 5.739625] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 5.740944] systemd[1]: Created slice system-postfix.slice - Slice /system/postfix.
[ 5.742233] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ 5.743067] systemd[1]: Created slice user.slice - User and Session Slice.
[ 5.743497] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 5.744497] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 5.744640] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-8ded0318\x2d01.device - /dev/disk/by-partuuid/8ded0318-01...
[ 5.744714] systemd[1]: Expecting device dev-disk-by\x2duuid-8cc3d0f8\x2dfa1c\x2d4107\x2d8ba6\x2d77f7c0ec5be2.device - /dev/disk/by-uuid/8cc3d0f8-fa1c-4107-8ba6-77f7c0ec5be2...
[ 5.744915] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 5.745155] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[ 5.745308] systemd[1]: Reached target slices.target - Slice Units.
[ 5.745461] systemd[1]: Reached target swap.target - Swaps.
[ 5.745649] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 5.746340] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 5.746663] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 5.747878] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 5.748530] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 5.749227] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 5.749981] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 5.750472] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 5.751387] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 5.783094] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 5.787568] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 5.792439] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[ 5.793271] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[ 5.799628] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[ 5.804593] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[ 5.809857] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 5.815612] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[ 5.822588] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[ 5.828650] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 5.836097] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 5.841961] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[ 5.847879] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[ 5.849348] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[ 5.859224] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 5.878425] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 5.885722] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[ 5.891936] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 5.907584] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 5.910936] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 5.912631] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 5.913956] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 5.914095] fuse: init (API version 7.39)
[ 5.922594] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 5.930636] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 5.932661] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[ 5.934622] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 5.935702] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[ 5.937565] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 5.938573] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ 5.944735] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 5.946627] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 5.949192] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 5.950113] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[ 5.955024] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[ 5.957938] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 5.960296] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[ 5.972227] i2c_dev: i2c /dev entries driver
[ 5.983202] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[ 5.988479] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[ 5.989086] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[ 6.001925] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[ 6.003983] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 6.005689] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 6.012070] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[ 6.022769] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
[ 6.028563] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[ 6.030096] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 6.030419] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 6.040495] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
[ 6.048265] systemd[1]: Starting systemd-sysusers.service - Create System Users...
[ 6.100255] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[ 6.128302] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
[ 6.131387] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 6.158808] systemd[1]: Finished systemd-sysusers.service - Create System Users.
[ 6.191522] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[ 6.192348] systemd[1]: Started systemd-journald.service - Journal Service.
[ 6.245301] systemd-journald[279]: Received client request to flush runtime journal.
[ 6.260454] systemd-journald[279]: File /var/log/journal/41431342e7df4b839de27d7cbf24f63b/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 7.537859] rpi-gpiomem fe200000.gpiomem: window base 0xfe200000 size 0x00001000
[ 7.538413] rpi-gpiomem fe200000.gpiomem: initialised 1 regions as /dev/gpiomem
[ 7.651740] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.654370] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.670462] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.670496] [vc_sm_connected_init]: start
[ 7.671025] mc: Linux media interface: v0.10
[ 7.675577] [vc_sm_connected_init]: installed successfully
[ 7.743186] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 7.773385] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.827380] videodev: Linux video capture interface: v2.00
[ 8.014453] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.041990] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.072539] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.085658] alsactl[375]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 8.295134] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.301592] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.306161] rpivid feb10000.codec: Device registered as /dev/video19
[ 8.306877] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.379683] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 8.380694] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 8.381676] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.382614] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 8.425107] Bluetooth: Core ver 2.22
[ 8.425237] NET: Registered PF_BLUETOOTH protocol family
[ 8.425246] Bluetooth: HCI device and connection manager initialized
[ 8.425267] Bluetooth: HCI socket layer initialized
[ 8.425279] Bluetooth: L2CAP socket layer initialized
[ 8.425302] Bluetooth: SCO socket layer initialized
[ 8.442443] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.442496] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.448200] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.448717] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.449084] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.449354] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.449377] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.449393] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.449405] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.449416] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.456662] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 8.457233] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 8.457650] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 8.458015] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.458043] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.458060] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.458071] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.458083] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.458253] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.487213] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.487262] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.509464] Bluetooth: HCI UART driver ver 2.3
[ 8.509493] Bluetooth: HCI UART protocol H4 registered
[ 8.509619] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 8.511490] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 8.511722] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 8.517671] Bluetooth: HCI UART protocol Broadcom registered
[ 8.579323] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.579370] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.631125] uart-pl011 fe201000.serial: no DMA platform data
[ 8.653698] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.653747] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.690484] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 8.690534] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 8.851737] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.865075] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.957132] usbcore: registered new interface driver brcmfmac
[ 8.959516] Bluetooth: hci0: BCM: chip id 107
[ 8.959914] Bluetooth: hci0: BCM: features 0x2f
[ 8.962878] Bluetooth: hci0: BCM4345C0
[ 8.962908] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 8.965606] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,4-model-b.hcd' Patch
[ 9.151233] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 9.152019] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[ 9.395915] BTRFS info (device sda1): first mount of filesystem 8cc3d0f8-fa1c-4107-8ba6-77f7c0ec5be2
[ 9.395969] BTRFS info (device sda1): using crc32c (crc32c-generic) checksum algorithm
[ 9.396002] BTRFS info (device sda1): using free space tree
[ 9.649753] BTRFS info (device sda1): enabling ssd optimizations
[ 9.649781] BTRFS info (device sda1): auto enabling async discard
[ 9.779168] Bluetooth: hci0: BCM: features 0x2f
[ 9.780561] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[ 9.780576] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[ 11.435930] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.435960] Bluetooth: BNEP filters: protocol multicast
[ 11.435984] Bluetooth: BNEP socket layer initialized
[ 11.446435] Bluetooth: MGMT ver 1.22
[ 11.481837] NET: Registered PF_ALG protocol family
[ 13.278992] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 13.280241] bcmgenet fd580000.ethernet eth0: Link is Down
[ 17.383472] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 22.988064] Bluetooth: RFCOMM TTY layer initialized
[ 22.988093] Bluetooth: RFCOMM socket layer initialized
[ 22.988111] Bluetooth: RFCOMM ver 1.11
[ 42.711836] Adding 204796k swap on /var/swap. Priority:-2 extents:10 across:4964352k SS
