example
longer
example
here
Nextcloud version (eg, 15.0.7):
Operating system and version (eg, Ubuntu 18.04.02):
Apache or nginx version (eg, Apache 2.4.29):
PHP version (eg, 7.2.17):
Mysql: 10.1.38
When I’am connect to the interface with admin user, and i want to see the users, i have an error, i can’t see old users but i can create new but not see after creating.
PASTE HERE
`Doctrine\DBAL\Exception\DriverException: An exception occurred while executing 'SELECT `uid`, `displayname` FROM `oc_users` `u` LEFT JOIN `oc_preferences` `p` ON (`userid` = `uid`) AND (`appid` = 'settings') AND (`configkey` = 'email') WHERE (`uid` COLLATE utf8mb4_general_ci LIKE ?) OR (`displayname` COLLATE utf8mb4_general_ci LIKE ?) OR (`configvalue` COLLATE utf8mb4_general_ci LIKE ?) ORDER BY `uid_lower` ASC LIMIT 25 OFFSET 0' with params ["%%", "%%", "%%"]:
SQLSTATE[42000]: Syntax error or access violation: 1253 COLLATION 'utf8mb4_general_ci' is not valid for CHARACTER SET 'utf8' at <<closure>>``
The output of your config.php file in `/path/to/nextcloud` (make sure you remove any identifiable information!):
PASTE HERE
The output of your Apache/nginx/system log in `/var/log/____`:
PASTE HERE
